“IBM cognos package” option in the TurboIntegrator
mincharug.shulft
OLAP Product: Applix,Cognos TM!
Version: applix9.0Cognos tm1 9.5.1
Excel Version: Excel 2010 2007
Post by mincharug.shulft »
Hello Gentle mans,
I am trying to access the “IBM cognos package” option in the TurboIntegrator as this “IBM cognos package” it’s not enabled so I gone to tm1s.cfg and added the below parameter and restarted the tm1 server though it’s not enabled .i would appreciate you if any help .thanks a lot.
CognosInterfacePath=http://localhost/cognos8/cgi-bin/cognos.cgi
NOTE: I have installed and configured my cognos 8.4 BI on the same machine
marco
Re: “IBM cognos package” option in the TurboIntegrator
Post by marco »
Do you have installed the correct TM1 Package Connector?
mincharug.shulft
while installation of cognos tm1 i selected all components.
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble »
You need to install TM1 Package Connector for BI 8.4 from its separate kit.
I think that TM1 9.5.2 was the last TM1 to include an 8.4 TM1 Package Connector kit.
You don't need to set anything in tm1s.cfg, Architect and TM1 Server on Windows will pick its location up from an environment variable that is set by the installer.
