TI ascii datasource - getTimeStamp(?)
yyi
Post by yyi »
hi Everyone,
I was looking for a function to read the time-stamp on a source file that's used to update a
cube several times during the day. If the chore 'looks' at the file and sees that it's late - ie:
skipped a drop file, then send an email alert to admin user.
Couldn't find any DateTimeStamp functions within TM1 so I used a long way:-
* ExecuteCommand() a vbs -> write-out timestamp to a text file
* Read text file to a parameters cube to record the times
* TI: read parameters and send email
There's probably a much better solution so if anyone knows of a pre-built function,
or find any flaws, pls let me know.
the *.vbs script
On Error Resume Next
sPath = "\\serverName\FTPdata\SAPftp"
i = 0
Set fso = CreateObject("Scripting.FileSystemObject")
Set fldr = fso.GetFolder(sPath)
Set iTxt = fso.CreateTextFile(sPath & "\TM1_timeKeeper.cma", True, False)
dtEnd = Now()
For Each fn In fldr.Files
  If fn.Name Like "*.txt" Then
    i = i + 1
    fnDts = fn.DateLastModified
    dtStart = DateValue(fnDts) + TimeValue(fnDts)
    fnDtIntv = DateDiff("n", dtStart, dtEnd) - (DateDiff("h", dtStart, dtEnd) * 60)
    iTxt.WriteLine fn.Name & "," & fn.DateLastModified & "," & i & "," & fnDtIntv
  End If
Next
iTxt.Close
the TI - pls ignore some superflous lines in the prolog
562,"CHARACTERDELIMITED"
586,"\\serverName\FTPdata\SAPftp\TM1_timeKeeper.cma"
585,"\\serverName\FTPdata\SAPftp\TM1_timeKeeper.cma"
#****GENERATED STATEMENTS START****
#****GENERATED STATEMENTS FINISH****
# PROLOG
fPathFile = 'E:\TM1\Admin\dw_ComposeMail.txt';
cYear = CellGetS('Parameters', 'Plan', 'wCurrentYear');
CheckSum = CellGetN('General Ledger', 'EBIT', 'ALLCCTR', 'All Entities', 'Total Year', cYear, 'Actual', 'Amount');
If (roundp(CheckSum, 2) < 0.50 & roundp(CheckSum, 2) > -0.50);
  ASCIIOutput(fPathFile, NumberToString(CheckSum));
Else;
  sRecipient = 'yyi@mydomain.com.au';
  sSubject = 'SAP GL - Trial Bal';
  sMessage = 'Balance = ' | NumberToStringEx(CheckSum, '#,##0.00', '.', ',');
  S_Run = 'cmd /c E:\TM1\Admin\SendMail.vbs' | ' "' | sRecipient | '"' | ' "' | sSubject | '" ' | '"' | sMessage | '"';
  ExecuteCommand(S_Run,0);
EndIf;
  S_Run = 'cmd /c E:\TM1\Admin\sapFtpTimeKeeper.vbs';
# try 1 for file lock
  ExecuteCommand(S_Run,1);
# METADATA
574,16
# DATA
If ( vFileName @= 'TM1_ACTUALS.txt' );
  CellPutS(vTimeStamp, 'Parameters', 'A', 'sapGLFile');
  CellPutS(vFileName, 'Parameters', 'B', 'sapGLFile');
  CellPutN(vLapse, 'Parameters', 'A', 'sapGLTimeDiff');
EndIf;
575,24
# EPILOG
timeStamp_Now = TimSt (Now, '\h:\i:\s');
timeStamp_File = CellGetS('Parameters', 'A', 'sapGLFile');
timeStamp_Lapse  = CellGetN('Parameters', 'A', 'sapGLTimeDiff');
If (timeStamp_Lapse  > 9);
  sSubject = 'SAP - FTP Fail ' | timeStamp_Now;
  sMessage = 'Time = ' | timeStamp_File | ' ~ ' | NumberToString(timeStamp_Lapse) | ' mins';
EndIf;
Yeon
Steve Vincent
Version: 10.2.2 FP1
Re: TI ascii datasource - getTimeStamp(?)
Post by Steve Vincent »
if the file is only ever called "TM1_timeKeeper.cma" then why not use a script to delete the file once it's been uploaded to TM1 instead? That way you could use FileExists in the TI rather than vb to get a date stamp. If it doesn't exist, do nothing otherwise run the import then run a vb script at the end to delete the file afterwards.
Yeon, there aren't any native TI functions to do anything with flat files other than check if they exist, read them, write to them and delete them. To check date stamps from the OS file system workarounds with batch files and/or vb scripting such as what you have come up with is more or less typical.
yyi
Post by yyi »
thanks guys for the feedback.
Steve, the del then 'fileExists' function's a good idea - actually the source file is gl balances and it get's picked up by sql svr ssis before it gets read in by tm1, so i didn't want to remove it.
Lotsa, how do you know me :o
maybe if executeCommand can get return values like executeProcess, ¿i could skip the text-stream routine ..
Yeon
