In previous versions the View Transaction Logs dialog appears to buffer 100 rows of entries at a time. When you page down or arrow down and hit the end of the current "frame" of entries, a further 100 entries will be loaded.
In 9.4, however, only the first 100 rows are returned. Paging down or arrowing down will yield no further entries, even if a physical check of the log file shows that there ARE further entries in the file.
This has been tested by various filters, and using no filters at all. It has also been tested in two separate server sessions. The results are always the same.
The server sessions are running on the same Windows XP computer (as remote, not local sessions), however that shouldn't make any difference since this is a client side issue.
Current Status (September 08): Screenshots (in the form of a Flash file ) submitted at Cognos' request.
11-81357561 TM1 9.4 - Transaction log returns only 100 rows
- Alan Kirk
- Alan Kirk
Re: 11-81357561 TM1 9.4 - Transaction log returns only 100 rows
This will apparently be fixed in 9.4MR1 (apparently MR is the new SP) due in November.Alan Kirk wrote:In previous versions the View Transaction Logs dialog appears to buffer 100 rows of entries at a time. When you page down or arrow down and hit the end of the current "frame" of entries, a further 100 entries will be loaded.
- Eric
- Version: 9.4
- Excel Version: 2003
When you first noticed it and I confirmed (shame on me don't think I posted a confirmation) I brought this to Corbett's attention . Glad to hear he jumped on top of it.
Eric
Eric
