Embedding Multiple Spreadsheets in HTML for TM1web
- Version: 10 2 2 FP3
I've been trying to embed multiple spreadsheets (3-4) using iframe into an HTML file and view them in a single screen in TM1web. One of and the main reason for trying to do this is the performance issues we're facing while trying to load the data into a single spreadsheet from several cubes in TM1 and also trying to write back to TM1. Current spreadsheet uses a lot of data validation, drop down values that are dynamically populated driven by user security.
Using iframe only allows us to embed files in html format and by doing that we lose functionality of the spreadsheet. Anyone here tried to embed multiple spreadsheets and were able to keep TM1web functionality? If so how?
Thanks in advance...
- LoadzaGrunt
- Version: LoadzaVersions
Re: Embedding Multiple Spreadsheets in HTML for TM1web
Did you publish your custom HTML page as an 'application' ? Otherwise I don't see why you would be trying to use TM1 Web.I've been trying to embed multiple spreadsheets (3-4) using iframe into an HTML file and view them in a single screen in TM1web.
If you are using the TM1 Web URL API correctly, then it is possible to have four websheets in four iframes in one custom page. What you won't get is the TM1 Web 'wrapping' without further effort.Using iframe only allows us to embed files in html format and by doing that we lose functionality of the spreadsheet. Anyone here tried to embed multiple spreadsheets and were able to keep TM1web functionality? If so how?
No, actually I used it as a home page for users by changing the webconfig file.Did you publish your custom HTML page as an 'application' ? Otherwise I don't see why you would be trying to use TM1 Web.
Do you have any examples you can share? I tried going through TM1 developer documentation, but couldn't figure it out...If you are using the TM1 Web URL API correctly, then it is possible to have four websheets in four iframes in one custom page. What you won't get is the TM1 Web 'wrapping' without further effort.
- LoadzaGrunt
I actually found the reference material on the TM1 URL API helpful. This was a pleasant suprise as sometimes TM1 documentation can be a little underwhelming.
I that when developing with the TM1 Web URL API, it's best to start off slowly with a simple requirement like just getting one page with one websheet, or one cubeview, up and running.
After going through the documentation(again) got it to work last night... I'm a happy camper
- Version: 9.5.1
I've got the same issue but actually i haven't found yet a solution.
I haven't understood what you're talking about? what is Iframe? could you give pls me and input in order to understand where to find a possible solution to fix this prob?
thanxs in advance,
Nicola
thanxs in advance,
Nicola
- LoadzaGrunt
You could start by teaching yourself HTML:I haven't understood what you're talking about? what is Iframe? could you give pls me and input in order to understand where to find a possible solution to fix this prob?
http://www.w3schools.com/html/default.asp
- Version: 9.5.1
Txs!!!
it works ....
I teached myself it !!:)
it works ....
- Version: 9.5.1
I've got a question again if you can.
I've done this htm page with two iframes. Each iframe contains one cubeview.
Whe from archietect, under my application try to launch the htm file it works and it shows me the two file in one html file.
But when I got to Tm1Web and i try to run it open it but after a second it appers a message that says "The action was aborted".
Why I'm not able to do it?
Is it a problem of security?
Any idea?
Nicola
Any idea?
Nicola
- Version: 9.5.1
sorry the actual message is "the thread was being aborted"
thnaks in advance for any help
