Recreating Hierarchy by Attribute
michalb
Version: 2.1
Post by michalb »
I use process in which I recreate hierarchy by attribute for certain dimension. I would say it is standard:
cDimName = 'Customer';
sAttrName = 'Customer Group';
sBlankSubstitute = 'No Cust Group';
sRootName = 'All Customer Groups';
sHierName = 'Customer Group';
IF ( HierarchyExists ( cDimName , sHierName ) = 1);
HierarchyDestroy ( cDimName , sHierName );
ENDIF;
CreateHierarchyByAttribute( cDimName, sAttrName , sBlankSubstitute , sRootName );
Problem occured when I started using hierarchy specific consolidation in a rule in one cube, containing that dimension, as a feeder. Now process that refresh hierarchy by attribute returns error:
Error: Prolog procedure line (74): Cost Plan Dimension Update Fail. Rule Is Invalid. Until rule is fixed
So I was thinking about three solutions:
- turn off rules in prologue of the process and then turn them on in epilogue (is it possible?)
- finding function that recreates hierarchy by attribute that don't require using HierarchyDestroy before (using CreateHierarchyByAttribute without using HierarchyDestroy before returns error)
- creating my own alternative hierarchy based on attributes without using function CreateHierarchyByAttribute and just use HierarchyDeleteAllElements instead of using HierarchyDestroy before
I would appriciate any recommended logical approches to this issue :)
Michal
burnstripe
Version: 2.0.9
Re: Recreating Hierarchy by Attribute
Post by burnstripe »
This would be the approach I would take
Except I would perform this all in the metadata tab. If the elements are destroyed and rebuilt in the metadata, as long as elements referred to in the rule still exist when the metadata completes you won't get the error you've been experiencing
JohnO
Version: 2.0.9.x
Excel Version: Office 365 16
Post by JohnO »
michalb wrote: Sat Oct 21, 2023 3:05 pm
I see CreateHierarchyByAttribute as just a way of simple introduction to building hierarchies. It's very limited in concept and application.
You will find most functions here:
https://www.ibm.com/docs/en/planning-an ... -functions
There there are more in here:
And here:
And maybe there are others.
And then concepts of the 'Leaves' is an important one in terms of what gets deleted when you maniupulate a hierarchy. I found this a short but useful reference:
https://cubewise.com/blog/hierarchies-e ... ent-model/ I think they were referring to "HierarchyDeleteAllElements" in that section about leaves.
There are also some additional rules functions.
it's really a whole new world which I think the majority have not ventured into because of the limited support to date (Including PAfE 2.0.90 in this statement) for hierarchies in the Excel/ websheet UI's. You really have to ensure that your existing rules will work with all hierarchies or educate users on the specific in when specific hierarchies can be used. And rule based aggregate overrides because a factor harder.
