MDX - How to use subset from one hierarchy to filter and generate subset on another hierarchy
lav4you
Post by lav4you »
Hi MDX experts,
I am trying to generate a subset based on two hierarchy from same dimension.
I am trying this in PAW. I have dimension Name 'Product'.
This dimension has two hierarchies.
'Product' and 'Leaves'
On 'Product' hierarchy I have subset name 'Engineering'.
Now I would like to apply this subset on 'Leaves' hierarchy and generate a dynamic subset through MDX in which it all leaf level members from 'Engineering' hierarchy.
Is this possible. I have tried using different approaches like TM1SubsetTo function or Generate function but everytime I get the CellsetMismatch: error.
For Eg.
TM1SubsetToSet([Product].[Product],"Engineering","Public")
Or
 {Intersect(
 [Product].[Product].[Engineering],
 [Product].[Leaves].Members
Give following error
provide a title
Validation failed.
Could not execute MDX expression. Error Code:rte295. Error:INTERSECT: Sets have incompatible dimensionality
Any help How can I achieve the same?
Lav
Re: MDX - How to use subset from one hierarchy to filter and generate subset on another hierarchy
Something like the below should work; it sounds like you were on the right track.
The trick is to think of hierarchies as completely separate entities, so you can take the "Name/Description" of an element from one (but that could come from anywhere as its just a bit of text) and the Member Unique Name that you build up in StrToMember is something completely different.
Generate
		{TM1FilterByLevel({TM1SubsetToSet( [Product].[Product], 'Engineering' )},0)},
		{StrToMember ( "[Product].[Leaves].[" + [Product].[Product].CurrentMember.Name + "]" )}
lav4you
Post by lav4you »
Thanks Declan,
This is great. I will tweak it a bit further to match some of my other filtering requirements.
But really helps.
Lav
