MDX wildcard filter based on cube value
CRP0021
Version: 10.3
Post by CRP0021 »
Just looking for a bit of advice compiling an MDX statement.
Here are some details:
I have a 2 dimensional cube called Sales which contains a Line dim and Measures.
I want to apply filters to the line dim based on values in the cube.
I'm able to apply filters properly when the value typed into the lookup cell matches exactly or is selected from a picklist, but I'm having trouble when the value typed into the lookup cell should be a wildcard search.
Here's a visual for more details. What I'm trying to achieve is the scenario 3 below.
Any advice would be greatly appreciated!
Line Filters.png (42.67 KiB) Viewed 2300 times
Re: MDX wildcard filter based on cube value
You can use INSTR e.g.:
{ FILTER(
   { TM1SUBSETALL( [Line] ) },
   INSTR([Sales].([Sales_m].[Manager]), "Bob") >0
INSTR documentation: https://docs.microsoft.com/en-us/sql/md ... rver-ver15
CRP0021
Version: 10.3
Post by CRP0021 »
Thank you Declan.
That works well.
One small wrinkle though if the lookup cell value is bob (lower case) instead of Bob this doesn't work.
I'd have to account for users typing in either I imagine.
I found this which actually works very well in PAW but not in PAX.
{FILTER([Line].MEMBERS,Instr(1,[Sales_m].[Manager],"bob",1)<>0)}
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
for PAX sheet,
imagine cell A1 contains the search text, e.g. Bob
To cater for lower or upper or any case input by the users you can do 2 things, firstly in another cell in the PAX worksheet have a formula something like =LOWER(A1), let us imagine that is in cell A2.
The MDX would then look something like this:
="{FILTER([Line].MEMBERS,Instr(1,LCASE([Sales_m].[Manager]),' " &A2& " ',1)<>0)}"
regards,
Mark
Mark RMBC wrote: Thu Apr 21, 2022 8:07 am To cater for lower or upper or any case input by the users you can do 2 things, firstly in another cell in the PAX worksheet have a formula something like =LOWER(A1), let us imagine that is in cell A2.
You could also skip the additional excel cell and just put lcase around A2 also (in the MDX formula) - just for the benefit of keeping all of the "logic" in 1 place.
CRP0021 wrote: Thu Apr 21, 2022 7:23 am I found this which actually works very well in PAW but not in PAX.
This is interesting - are you sure it is working differently in PAW to PAX?
This formula is pretty much the same as what I initially provided, the only real difference is instead of TM1SubsetAll it uses Members. This will give you the same result, as long as there is only 1 instance of each element in the hierarchy. If the same element exists under multiple parents, .members will give you multiple results.
But if it truly is working differently in PAW and PAX, then something sounds wrong. Both *SHOULD* be using the same engine.
Just did a quick test. You are right, PAW is completely case insensitive and accepts upper or lower case for INSTR searches.
That's new information to me - I don't like the same MDX in different tools producing different results.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Oh yeah! ;)
News to me too and I don't like that either!
regards,
Mark
Not sure that your MDX is correct here as you dropped the reference to the Sales cube before addressing [Sales_m].[Manager]
Possibly this would work:
{FILTER([Line].MEMBERS,Instr(1,[Sales].([Sales_m].[Manager]),"bob",1)<>0)}
Also, AFAIK, the 4th argument, that MS MDX says is ignored and is for compatibility, I have always used as a 1 to indicate ignore case.
I ran some rudimentary test in PAfE and setting the 4th argument to 0 only matches exact case, setting to 1 ignores case.
Keith Would
Version: 10.3.0
Post by Keith Would »
This is really helpful, thanks everyone.
While testing, I wrote the wrong dimension name in the cube, but it still worked (in PAfE)?
It doesn't work if you don't put in any dimension name.
{FILTER([Permanent Staff].MEMBERS,Instr(1,[Current year staff forecast].([Year for payroll total].[Forename]),"an",1)<>0)}
'This one below works as well somehow, despite referring to the wrong dimension for Forename?
{FILTER([Permanent Staff].MEMBERS,Instr(1,[Current year staff forecast].([Permanent staff].[Forename]),"an",1)<>0)}
