MDX Error: Get cell value: Cannot get cube cell value
Palczan
OLAP Product: TM1 Cognos
Version: 11.3.0.27
Excel Version: Office 365 MSO 64bit
Post by Palczan »
Hello Everyone,
today I have a problem with mdx. I write a simple MDX. This mdx is bellow:
{FILTER(
{TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim Product] )}, 0)},
[Security Type].(StrToMember("[}Clients].["+USERNAME+"]") ,[Dim 1].[Total of Dim 1],[Dim 2].[Element 2],[Dim 3].[Element 3]) > 0
Unfortunately, I can run this mdx when I am a admin but when I change a user I can't run this MDX. The statement is consecutive:
I add permission to this Cube and all using dimensions for all users on server.
Anybody, has a similar problem?
Kamil
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: MDX Error: Get cell value: Cannot get cube cell value
Post by Elessar »
I assume your user does not have have access to the "Security Type" cube or to dimensions' elements. Try to open this "[Security Type](user, [Dim 1].[Total of Dim 1],[Dim 2].[Element 2],[Dim 3].[Element 3]" in Architect
TM1 and Data Science blog: 7th article - Development requirements.
Palczan
Version: 11.3.0.27
Post by Palczan »
Thanks Ellesar for your answer.
Now i have permission to the Cube and Dimensions using in this Cube. I set a WRITE permission on intersection.
On this server I'm using Dataresrvationmode but for different cube.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
You do not need "WRITE", "READ" is enough
Try to check whether your user can access to this slice in tm1web/architect: "[Security Type](user, [Dim 1].[Total of Dim 1],[Dim 2].[Element 2],[Dim 3].[Element 3]"
Also check if the user has access to }Clients dimension and it's elements
