Executing temporary bat files using TI
Version: PAL 2.0.9.18
Hello
I thought I would post up a simple example in a TI process to generate a batch file, execute it, and kill it.
The process creates the file usernames.bat in the folder C:\BV. After that, it executes the bat file and kills it again. As a result, the username in Windows is appended to the file C:\TM1\usernames.txt
Steps to reproduce:
Create a new process
In the Prolog tab:
# 0. preliminary
vTempFileName='C:\BV\username.bat';
DatasourceASCIIQuoteCharacter='';
# 1. create the temporary bat file
ASCIIOUTPUT(vTempFileName,'cd "C:\TM1"');
ASCIIOUTPUT(vTempFileName,'echo %username% >> usernames.txt');
In the Epilog tab:
# 2. execute the file
EXECUTECOMMAND(vTempFileName,1);
# 3. kill the temporary bat file again
ASCIIDELETE(vTempFileName);
Feel free to extend the approach taken, by making the bat file more "interesting". For instance, using the Metadata and Data tabs you could setup more difficult situations.
IBM Champion 2024
