Hello Everyone,
This is my first post on the forum. There is an issue I'm having and could not find a definitive answer for it. Hope someone can help me.
The navigation in my TM1 model is almost completely managed by worksheets, URL API links. However, some of my cubes have drill-through definitions. The thing is whenever you go to a cube view via a URL API link, for some reason drill functionality just disappears. If I open the view via the Navigation pane, everything is fine.
In short, drill-through functionality seems to be completely dependent on how you access the content: If it's URL API then no luck, otherwise it's fine.
Do you have any idea as to how to enable drill-through on a view which is accessed by URL API?
Thanks in advance.
Edit: By the way, the version I use is the latest Planning Analytics 2.0 local version.
Drill Down - URL API Problem
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: Drill Down - URL API Problem
This is by design: http://www-01.ibm.com/support/docview.w ... wg1PI32028
However, there is an RFE, please vote: https://www.ibm.com/developerworks/rfe/ ... R_ID=73579
- Version: 10.3
- Excel Version: 16
Thanks Elessar.
I hope IBM does it soon...
Well the RFE is from 2015 ...
