SUBNM in TM1Web
Willi
Version: 9.5.2
SUBNM in TM1Web
Post by Willi »
we're running TM1 Planning Analytics and I try to realize a couple of SUBNMs to choose different Elements from the same Dimension. In Excel it looks like:
If I select an Element in one of the SUBNMs in TM1Web it looks like:
That means that the selection is written in every SUBNM. The formula looks like:
=SUBNM($B$11;"Ausgleich_"⋐$C165)
The Index $C165 is different for every line to get different initial values. But the referenced cells are not filled during the Selection. I even tried to use different Dimension-References. Means: same content because it's the same dimension, but different cell-references. But it's still the same that the cells are all filled.
Any idea why this happens and how to avoid?
Thx and best regards.
Version: PAL 2.0.9.18
Re: SUBNM in TM1Web
Just for testing, does it work it work if you hardcode the first 2 parameters in the SUBNM ?
IBM Champion 2024
Willi
Version: 9.5.2
Re: SUBNM in TM1Web
Post by Willi »
I‘ll try in the Evening today. Thx
Willi
Version: 9.5.2
Re: SUBNM in TM1Web
Post by Willi »
Interesting. That's working. I'll make further Tests tomorrow. I Need a dynamic Name für the subset and the index.
MGrain
Version: Various
Excel Version: Various
Re: SUBNM in TM1Web
Post by MGrain »
The problem is most likely due to the ampersand &. I’ve experienced issues in TM1Web with concatenation, particularly when building MDX queries dynamically.
Try putting
 ="Ausgleich_"&Subset
into a separate cell and referencing that cell instead.
Willi
Version: 9.5.2
Re: SUBNM in TM1Web
Post by Willi »
That makes no difference.
I changed it now to one SUBNM with a TI-button to transfer the value. The button was already there with a slighty different meaning but it's okay. The user can live with ist.
But there is still a problem in TM1Web with a SUBNM and the Index-Parameter. When I have a bit more time I'll try to break it down.
Thx to all suggesting a solution.
