Hi ,
I have an AR cube which has a customers dimension like
All Region -> Region -> Agency->Rep-> Customers .
Now there is a rule in the cube which takes the customer element and pulls data from sales cube .
Now there was a requirement to see customers by collection specialist , so I created an alternate hierarchy in Customers dimension to include
AllCOllectionSpecialist -> CollectionSpecialist -> Customers
Now the issue I am having is the sales cube doesnt have this grouping , so the value for collectiona specialist is returned as zero and all the customer below it has has the values .
I cannot bring in the alternate hierarchy in sales cube .
Is there a way I can tell to overwrite the calculation for the sales column to aggregate its children total , when its parent is All collection specialist or it itself is All Collectionspecialist .
Issue with Pulling data from Sales Cube for AR Cube
- OLAP Product: Tm1
- Version: 9.5
- OLAP Product: Tm1
- Version: 9.5
Re: Issue with Pulling data from Sales Cube for AR Cube
Now I cannot use ELPAR in my rule to pass the value based on condition since i have multiple Hierarchies .
- Version: PAL 2.0.9.18
Typically you would use an attribute to store the desired parent. This way you avoid the problem of Elpar with multiple hierarchies.Analytics123 wrote: ↑Fri Feb 16, 2018 2:57 pm Now I cannot use ELPAR in my rule to pass the value based on condition since i have multiple Hierarchies .
IBM Champion 2024
IBM Champion 2024
- OLAP Product: Tm1
- Version: 9.5
Okay thanks , I will use Attributes and how doI pass the elements all children in the rule .
DB('Sales',!Customers,!months,'Full Revenue');
If Attribute value is true then I need to pass all the children of the selected customer .
