Hi guys,
for some views in our PAW books we are getting "Unable to fetch data" error, see attached.
What exactly does this mean? I'm able to open the same view in PM or in TM1 apps web.
Thanks for any suggestion!
BR
Vladino
"Unable to fetch data" in PAW book
- Excel Version: Excel 2013
- PAW_unable_to_fetch_data_error.png (2.17 KiB) Viewed 3723 times
- macsir
- Version: PAL 2.0.9
Re: "Unable to fetch data" in PAW book
Have you setup session limit for that user? You need to use 0 which is unlimited, otherwise it will reach the upper limit quickly.
- macsir
Max Connections
- Excel Version: Excel 2007
Open the developer tools window for your browser.
In the Network panel, look for the command that returns an error.
Check the details of the command, it should have more information.
Alternatively you can use Fiddler to capture the information.
