Hi there,
I am facing difficult to use format number as 1.000.000,00 instead of 1,000,000.00.
I am using Planning Analytics on SaaS.
The problem is when I run the process to upload data from a csv to a cube.
I have changed the region configuration as word file attached but as example the number 0,12 is 12 on tm1 and I don't know what to do anymore.
Does anyone have an idea?
Thanks a lot,
JR
Region Settings
- Version: 10.2
- Excel Version: 2013
Region Settings
- Problem.docx
- Region Configuration and result on TM1 from CSV file
- (61.17 KiB) Downloaded 247 times
- CsvFile.csv
- File uploaded to tm1
- (183 Bytes) Downloaded 258 times
- OLAP Product: tm1
- Version: 10.2.0 - 10.3.0
Re: Region Settings
If you use TI to load data you must define decimal separate char and thousand saparate char in TI.
- Version: 10.2
Re: Region Settings
My TI is like that but it is still not working.
TM1 is ignoring the comma and I don't know why.
- Version: PAL 2.0.9.18
Re: Region Settings
If your variable is defined as a string, try the function StringToNumberEx, and specify the separators.
Does that work ?
See http://www.wimgielis.com/tm1_numbersandstrings_EN.htm
Does that work ?
IBM Champion 2024
IBM Champion 2024
- Version: 10.2
Re: Region Settings
Hi Wim,
Amazing!
I have tried here and seems to work!
I will fix all variables that I have on TI but I am quite sure that will work.
Thank you so much.
JR
Amazing!
Thank you so much.
JR
- Version: 10.2
Re: Region Settings
Hi Wim,
Everything is correct now!
Thanks a lot for your help again.
See ya,
JR
See ya,
JR
Re: Region Settings
You're welcome
IBM Champion 2024
IBM Champion 2024
