I’m having issues with Action buttons resizing when I open my active reports.
It is quite a “wide” report with action buttons above a few columns.
When I re-open the report, the button are really tiny and I then have to resize.
Googled this, and found stuff about this being logged as a bug as far back as 2015. Client is running 10.2.2 FP6.
Any ideas?
Thanks!!
Action Buttons Resizing
- Version: PAL 2.0.9.18
Re: Action Buttons Resizing
Action button problems date back to before 2015, and still not solved unfortunately.
Currently we have a customer (also on TM1 10.2.2.6) logging a case with us, because:
- the buttons resize
- the buttons become a picture and not clickable anymore
- the font size increases to 975 (go figure !)
- some PC's work while others give these issues
- and so on
Most of the time working with Action buttons is just "trial and error and not touching the buttons again"
The Print report wizard is similarly crappy. Another customer is logging a case on it currently. The customer moved to PAL.
- and so on
IBM Champion 2024
IBM Champion 2024
I've been dogged with the action button resizing for years. It's a real PITA. Strangely enough It's related to the display resolution on your PC. As long as the person editing the actions buttons have the same type machine with identical display resolutions as the person who created them then everything is stable. Once that switches then all heck breaks loose. It's really bad when you have used action buttons to create a nice looking menu. The resizing messes up your layout. What I've ended up having to do is document the coordinates and size of each button so that whenever the menu needs editing I can fix all the "resized" action buttons, one by one. Not an ideal situation.
- Version: 10.1.1
- Excel Version: Excel 2010
Normally I would have expected the response to this to be along the lines of change the Placement property to 1 on the Active Form (I did notice Chewza said Active Report and not Active Form).
So my question is, what am I missing here? Which given the responses above from the experts is clearly something!
- gtonkin
I saw this quite often when pluggin in an additional screen, whilst the TM1 add-in is open. Standard practice used to be close down, plug in, restart client.
Saying that, there are still times when the inexplicable happen, per above posts. To this end, in my aresenal of macros in my Personal.xlsb, I have one as follows:At least it is temporary relief for the symptoms.
Public Const iButtonWidth As Integer = 85
Public Const iButtonHeight As Integer = 26
Sub FormatTIButtons()
Dim TIButton
For Each TIButton In ActiveSheet.Shapes
If TIButton.Type = 12 Then
If Left(TIButton.OLEFormat.progID, 5) = "TM1XL" Then
TIButton.Top = (TIButton.TopLeftCell.Height - TIButton.Height) / 2 + TIButton.TopLeftCell.Top
TIButton.Left = TIButton.TopLeftCell.Left + 1
TIButton.Width = iButtonWidth
TIButton.Height = iButtonHeight
End If
End If
Next
End Sub
- Version: 2.5 to PA
- Excel Version: Lots
I'm with you. I always set any Action Button's Placement to 1 and don't have any re-sizing problems.Mark RMBC wrote:Normally I would have expected the response to this to be along the lines of change the Placement property to 1 on the Active Form (I did notice Chewza said Active Report and not Active Form).
Andy Key
