Report Studio. Using data from TM1 and Relational DB
abulloch
Version: 9.4
Post by abulloch » Wed Jan 19, 2011 1:18 pm
Good day.
I need to create a report that shows variances between sales data off TM1 cube and what is actually in Syspro Database. My report currently shows both sets of data, each in it's own crosstab. Is it possible to somehow reference the two crosstabs in order to get a variance in a separate crosstab?. The final variance is the result I require. This can be in a separate report.
Any ideas.
regards
Allan Bulloch
Re: Report Studio. Using data from TM1 and Relational DB
Post by David Usherwood » Wed Jan 26, 2011 10:58 pm
Why not pull the relational data into TM1? Variances would then be very easy and fast.
kharon
Version: 9.5
Post by kharon » Fri Jan 28, 2011 10:48 am
Of course that's a way to pull the data into TM1, but that will be another data copy step...
If you want to avoid that, you can try to join your result queries and create a third query to show both (and the variance)
ParisHilton
OLAP Product: Tm1
Version: 9.5
Excel Version: 2007 2010
Post by ParisHilton » Wed Jan 09, 2013 12:46 pm
But of course, if you do it in the report, you open the door to other users doing it in the report, and then doing it differently and then giving two different answers ;)
“The way I see it, you should live everyday like its your birthday”
TM1 9.5 Cognos BI 8.4 Excel 2007. 128GB Ram. E7450@2.40Ghz -24 core. Fluffy white dog.
