Action Button - Process Failed - with No Log
chewza
Version: 9.5
Excel Version: 7
Post by chewza »
Hi there
I get a "Process Failed" message from an action button. No error log or entry in Tm1Server log.
Any ideas?
Many thx!
Version: PAL 2.0.9.18
Re: Action Button - Process Failed - with No Log
TM1 Perspectives ? PAfE ? A sheet dragged on a PAW dashboard ?
The process exists ? For instance, in case the process name could be retrieved dynamically from a cell.
Process parameters are fine ?
IBM Champion 2024
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
chewza wrote: Thu Apr 11, 2024 5:04 pm Hi there
Any ideas?
Many thx!
Make sure all the parameters you're passing include an "=" in the box. Easy to miss this if using named ranges.
dimAccount (wrong)
=dimAccount (correct)
Ty
Cleveland, TN
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
May be user doesn't have rights for the process.
In this case I see the same behaviour
User clicks on button, see error window and nothing in log file
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
This is an indication that the process did not get triggered at all, and usually this is due to security access or the name of process is not spelled correctly.
If the name of Process is in a reference cell then check the cell, i usually use Named Ranges for process name, process params, and all other properties of action button
Ardian Alikaj
konstantin-spb
Version: PA 2.0.9
Post by konstantin-spb »
1) No security rights to run the process;
2) There are many models on one server
and a different model is specified for the button.
Logs are written to a log file of a different model.
chewza
Version: 9.5
Excel Version: 7
Post by chewza »
Thx all - got it sorted! Issue with named range in Excel
