TI not writing string value to consolidated element
kenship
OLAP Product: Cognos
Version: Planning Analytics 2.0.7
Post by kenship » Thu Oct 08, 2020 3:23 pm
I have trouble writing to consolidated element of a cube. Here's some details of how I setup the TI process:
Data Source: Cube View - Target cube
Variables: Based on Target cube dimensions, Variable Type all "String", Contents all "Other"
Prolog:
1. Setup Target view and Target subset in Target cube
2. Setup Target subset using MDX that include leaf and consolidated elements for a few dimensions
3. Assign MDX of each dimension to Target subset
4. Assign Target subset to Target view
5. Activate ViewExtractSkipZeroesSet and ViewSuppressZeroesSet of Target View in Target Cube
Data:
CellPutS to Target Cube based on variables for each dimension. Content is referenced to another cube using CellGetS.
My problem is that it works fine for intersection on the leaf level but nothing is written to consolidated level elements as defined by the Target View and Target Subset.
Appreciate any help.
Kenneth
ascheevel
Version: PA 2.0.8
Re: TI not writing string value to consolidated element
Post by ascheevel » Thu Oct 08, 2020 3:37 pm
Make sure your TI source view isn't skipping consolidations: ViewExtractSkipCalcsSet?
kenship
Post by kenship » Thu Oct 08, 2020 3:52 pm
Thanks for the reply. I checked the view and it does include the consolidated elements.
I've been testing by changing the CellPutS to special consolidated elements instead of variables and it worked. But I need the CellPut command to put content according to how the View is setup. I don't know if using variables is the right thing to do at all.
Kenneth
ascheevel
Version: PA 2.0.8
Post by ascheevel » Thu Oct 08, 2020 3:56 pm
Post some code?
Version: PAL 2.0.8
Post by Wim Gielis » Thu Oct 08, 2020 5:07 pm
Did you look at ViewExtractSkipConsolidatedStringsSet ?
https://www.wimgielis.com ==> 117 TM1 articles and a lot of custom code
Newest blog article: Using TI to change elemant names, like Biden to Trump
kenship
Post by kenship » Thu Oct 08, 2020 6:03 pm
For simplicity, I created a very small cube to show what I'm trying to accomplish.
The cube includes:
DimA - (A-TOTAL)->A1, A2
DimB- (B-TOTAL)->B1, B2
Dim_m- $, Description
What I'm trying to do is to put string into "Description" for consolidated elements (A-TOTAL), (B-TOTAL) when $ has value.
The image shows only leaf element has string value based on the CellPutS.
Screenshot 2020-10-08 134531.png (19.83 KiB) Viewed 287 times
Here's my TI process
1. Data Source: Cube View, Demo->DimOrder
2. Variables: vDimA, vDimB, vDim_m, vValue, Variable Type: String, Contents: Other
3. Prolog:
tCube = 'Demo';
tSubset = 'tsubset';
tView = 'tView';
IF(ViewExists(tCube, tView) = 1);
    ViewDestroy(tCube, tView);
ENDIF;
ViewCreate(tCube, tView);
vIndexDim = 1;
WHILE(TABDIM(tCube, vIndexDim) @<> '');
	vDimName = TABDIM(tCube, vIndexDim);
	IF(SubsetExists(vDimName, tSubset) = 1);
		SubsetDestroy(vDimName, tSubset);
	ENDIF;
	vMDX = '{TM1SUBSETALL( [' | vDimName | '])}';
	SubsetCreateByMDX(tSubset, vMDX);
	ViewSubsetAssign(tCube, tView, vDimName, tSubset);
	vIndexDim = vIndexDim +1;
END;
ViewExtractSkipZeroesSet(tCube, tView, 1);
ViewSuppressZeroesSet(tCube, tView, 1);
DatasourceCubeView = tView;
4. Data
CellPutS('Check',tCube,vDimA,vDimB,'Description');
Again, this process put the text string "Check" into leaf element but not for consolidated level element.
Thanks!
Kenneth
ascheevel
Version: PA 2.0.8
Post by ascheevel » Thu Oct 08, 2020 6:16 pm
Can you add the below items to your prolog below the other ViewExtract... declarations and re-test?
ViewExtractSkipCalcsSet('tDemo', 'tView', 0);
ViewExtractSkipRuleValuesSet('tDemo', 'tView', 0);
kenship
Post by kenship » Thu Oct 08, 2020 6:41 pm
Looks like it's the ViewExtractSkipCalcsSet that needs to be inserted.
Thanks very much!
