CSV file as data source, why TI is reading one more column?
lynnsong986
Post by lynnsong986 » Thu Nov 07, 2019 9:15 pm
I have a CSV file with 12 columns as data source, but the preview shows V1.......all the way up till v13 (all blanks underneath it - v13 is non existing in the CSV, column 13 has absolutely nothing), also there are 13 variables in the Variable tab. How can I get rid of this v13?
thanks so much!
ascheevel
Version: PA 2.0.8
Re: CSV file as data source, why TI is reading one more column?
Post by ascheevel » Thu Nov 07, 2019 9:20 pm
What harm is variable V13 causing you? You can simply ignore it.
lynnsong986
Post by lynnsong986 » Thu Nov 07, 2019 10:23 pm
it's not causing anything really, I just don't understand why it showed up...but I guess I can definitely ignore it :) sounds like this does happen in TM1... thanks!
Post by lotsaram » Thu Nov 07, 2019 11:19 pm
Because number of fields = number of separators + 1
If the last field has a trailing separator then this marks the start of a new field.
Version: PAL 2.0.8
Post by Wim Gielis » Thu Nov 07, 2019 11:59 pm
Indeed, make sure there are not additional separators.
If an Excel file is the basis for the csv, then make sure that the last cell in Excel (Ctrl-End) matches the last cell of your data.
If not, remove all columns (and rows) that are excessive, save the file (important!) and then save as csv again.
Newest blog article: Selecting elements in the Subset Editor quickly
lynnsong986
Post by lynnsong986 » Fri Nov 08, 2019 1:18 am
Wow that must be it!! thanks so much for your time letting me know!
