Tm1 Action button - call Macro
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 » Tue Sep 24, 2019 1:26 pm
Hello Everyone,
I have worked on basic TM1 Action button which calls the TI process.
I have got a below report to develop
but here 'Actuals' is textbox and it calls the macro which in turn call Application.Run "ExecuteActionButton", "2325345". All the menu icons are named as TM1Button. I cant see much info from this report.
Its something like calling the macro which in turn calls the TI process?? How can I develop the report like this? Is it Possible?
Thanks in advance for all who spend time on this.
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Excel Version: Plus 2013
Re: Tm1 Action button - call Macro
Post by HighKeys » Wed Sep 25, 2019 8:13 am
Hola!
As i know u have to use "Action Buttons" from TM1 to trigger TI Processes.
TI Excel.PNG (31.95 KiB) Viewed 5060 times
BR
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Thu Sep 26, 2019 6:24 am
Yes I know. Thanks.
Is there other possibility of calling the macro via Tm1 Action button?
orlando
Version: PAL 2.0.8
Post by orlando » Thu Sep 26, 2019 9:12 am
Yes I know. Thanks.
Nope. I don't think there is any supported way to do so.
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Thu Sep 26, 2019 9:20 am
What do you want to do ? Using a shape or textbox instead of an action button, and then the consequence is that you can't easily run TI processes ?
https://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Thu Sep 26, 2019 3:01 pm
yes, exactly. I would like to make a report with shapes or textboxes and call the TI process via macros. Above I have attached the sample report for reference.
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 26, 2019 3:12 pm
In what client(s) should it work ?
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Fri Sep 27, 2019 6:53 am
It should work in excel (TM1 Perspectives).
Version: 10.2.2., PAW
Post by Steve Rowe » Thu Oct 03, 2019 4:06 pm
If you are using PA for Excel then (your opening posts looks like PA for Excel but later you say Perspectives)
https://ibm.github.io/paxapi/#introduction
If you are using Perspectives then you can write calls using the old API but it is much much more involved. You may find some good material with some googluck but I don't think the code is widely shared due to the level of effort required to produce it.
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Fri Oct 11, 2019 11:06 am
Thanks for reply and suggestion.
Post by tomok » Fri Oct 11, 2019 1:40 pm
IIf you are using Perspectives then you can write calls using the old API but it is much much more involved. You may find some good material with some googluck but I don't think the code is widely shared due to the level of effort required to produce it.
With all due respect this is a really bad idea if you care about the longevity of your solution. Once IBM kills the old API (and it's happening, only a question of when) then all your work will go down the toilet. Better to look for a solution using PAX action buttons or calling something in the REST API.
