Copy cub files
MarenC
Excel Version: Excel 2016
Copy cub files
Post by MarenC » Tue Aug 13, 2019 3:34 pm
is there any issue with copying .cub files to another folder while the tm1 instance is still running. Or should the instance be stopped first?
Maren
Emixam
Re: Copy cub files
Post by Emixam » Tue Aug 13, 2019 3:56 pm
There's no issue of copying (CTRL-C) a .cub file but there's a risk for sure if you cut (CTRL-X) or delete a cube. Also, don't forget to CubeSaveData(sCube) if you want to most recent data.
That being said, I always ask to my collegue to "NEVER TOUCH THE DATA FOLDER WHEN THE SERVER IS RUNNING".
Cheers !
Sorry for my English :)
Re: Copy cub files
Post by tomok » Tue Aug 13, 2019 7:09 pm
Maren
As long as you understand that the .cub file is nothing more than a backup to disk of the cube in memory, minus any changes since the last CubeSaveData or SaveDataAll command was issued, then no, there is no issue with copying it anywhere.
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Re: Copy cub files
Post by Wim Gielis » Tue Aug 13, 2019 8:56 pm
And, assuming that this cube is going to be used in a TM1 model, make sure the relevant dimensions are up to date as well.
https://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Updating process line numbers with AutoHotKey
MarenC
Re: Copy cub files
Post by MarenC » Wed Aug 14, 2019 12:29 pm
Excellent, thanks for the advice.
