TM1 WEB context area
rihab
OLAP Product: TM1 in memory
Post by rihab » Fri Jun 28, 2019 3:42 pm
I have an issue here when i'am opening one of the cube view with 13 dimensions on the web , i cannot see all the dimension on the context menu,
so i want to know if there is away (parameter) that i can resize the drop area so that i can see the all hidden dimensions.
regards
Rihab
Version: PAL 2.0.8
Re: TM1 WEB context area
Post by Wim Gielis » Fri Jun 28, 2019 3:50 pm
You do have a dropdown (2 arrows) at the bottom right of the screen, no ?
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
rihab
Post by rihab » Fri Jul 12, 2019 1:28 pm
Hello wim,
As you can see in yellow, i must open the arrow to see other dimensions, so this is my problem.
I want to see all dimension in the same area like Architect, i don't want to open the arrows in every time
Any suggestions?
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Wed Jul 17, 2019 1:28 pm
you can change class
.tm1webHidden {
display: none !important; <--change this
In flat.css on default themes(flat)
BUT i do not find how show horizontal scroll tab. Maybe some one skilled find the solution.
