Updating cubes across different applications with TI
Rtel
Post by Rtel » Thu Jun 06, 2019 3:30 pm
Hi, I am writing a TI to update data in a cubes in one application. This needs to be followed by change data in a cube in another application also.
So is it possible to write a TI process to update values in a cube in a different application ?
or
How can I have a TI process from one application call another TI process from another application and pass a string parameter. ?
Rtel
ascheevel
Version: 11.2
Re: Updating cubes across different applications with TI
Post by ascheevel » Thu Jun 06, 2019 3:36 pm
You can use RunTI to call a TI process on another TM1 server. You can pass parameters to the called process when using RunTI.
https://www-01.ibm.com/support/docview. ... 6543&aid=1
Version: PAL 2.0.7
Post by Wim Gielis » Thu Jun 06, 2019 4:00 pm
What do you mean with Application ? A websheet / view / ... or is a TM1 server (model) ?
It it's a different model you could look at TM1RunTI.exe (or similar solutions but TM1RunTI.exe is the basis).
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 service with AutoHotKey
Rtel
Post by Rtel » Mon Jun 10, 2019 3:51 pm
Hello All, Thanks for your responses. I will explore the direction provided.
Hi Wim, by 'Application' I meant a TM1 server modal.
Rtel
