We just upgraded from 2.0.4 to 2.0.6 and realize many processes that utilize the automatic clearing of temporary view and subset not working for us.
It seems like if a process chain is called the clearing won't happen until the end of the process chain. In 2.0.4 it seems to be cleared at the end of each process.
We have a few process chains and within the chain the same dimension is re-engaged and now in 2.0.6 it couldn't proceed with it.
I'm now changing the TI to clear clear out the subset at the end of each process or to rename temporary subset different, but I wonder if someone else experience the same issue.
Thanks.
Kenneth
PA 2.0.6 Temporary Subset Unable To Register
- Version: PAL 2.0.6
- Excel Version: 2016 - Office 365
Re: PA 2.0.6 Temporary Subset Unable To Register
Hi Kenneth,
I can relate to this problem. But I have no solution.
2 weeks ago after upgrading a TM1 model, I had to rewrite certain view and subset creations because of this issue with temporary objects. It was most of the time a mother process looping over 12 periods and within the loop a second process was called with a parameter for the period. After explicitly deleting the temporary views and subsets, the code ran just fine. It shouldn’t be necessary though.
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
- OLAP Product: Cognos
- Version: TM1 10.2
Thanks for your reply.
I just want to confirm that I'm not the only one who has this problem.
Ken
Ken
Confirmed
And thanks for confirming my suspicions about the subject.
I would suggest that a far better approach to deleting a temporary view or subset (which is a bit of an oxymoron) would be to ensure that all temp objects are assigned unique names.
e.g.
Actually it is a longstanding gripe of mine that the implementation of temporary objects was done very poorly leading to a far reduced scope where they can be used and encouraging poor coding practices due to temp objects being accessible only to the immediate TI process which created them as opposed to persisting for the duration of a transaction (and therefore being available to library function processes which would make them much more useful!) There is likewise fairly long in the tooth enhancement request for this which IBM declined. Seeing this change of behavior gives me some hope that IBM has reconsidered and might be on the path to making temporary views and subsets a worthwhile and useful feature. Well we can live in hope.
e.g.
cTempView = 'whatever';
cTimeStamp = TimSt( Now, '\Y\m\d\h\i\s' );
sRandomInt = NumberToString( INT( RAND( ) * 1000 ));
sTempView = Expand('%cTempView%_%cTimeStamp%_%sRandomInt%');
- Version: TM1 10.2
Thanks for the reply.
I probably won't go as far as you but like I said I either apply view and subset clearing in epilog or name the subset uniquely depending on the situation.
Kenneth
Kenneth
lotsaram wrote: ↑Sun Dec 09, 2018 3:34 pmI would suggest that a far better approach to deleting a temporary view or subset (which is a bit of an oxymoron) would be to ensure that all temp objects are assigned unique names.
e.g.Actually it is a longstanding gripe of mine that the implementation of temporary objects was done very poorly leading to a far reduced scope where they can be used and encouraging poor coding practices due to temp objects being accessible only to the immediate TI process which created them as opposed to persisting for the duration of a transaction (and therefore being available to library function processes which would make them much more useful!) There is likewise fairly long in the tooth enhancement request for this which IBM declined. Seeing this change of behavior gives me some hope that IBM has reconsidered and might be on the path to making temporary views and subsets a worthwhile and useful feature. Well we can live in hope.Code: Select all
cTempView = 'whatever'; cTimeStamp = TimSt( Now, '\Y\m\d\h\i\s' ); sRandomInt = NumberToString( INT( RAND( ) * 1000 )); sTempView = Expand('%cTempView%_%cTimeStamp%_%sRandomInt%');
