Tm1 PAX plugin disappears
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 » Thu Oct 04, 2018 2:00 pm
Hello Everyone,
I have a problem in TM1 PAx plugin, its was working fine, and suddenly crashed. Then IBM Planning Analytics Menu in excel was disappeared. I have tried adding it in excel addin, then close the excel and reopen. Again IBM Planning Analytics menu was not there.
Any suggestions, welcome. Thanks.
Paul Segal
Re: Tm1 PAX plugin disappears
Post by Paul Segal » Thu Oct 04, 2018 2:25 pm
Did you put the COM add-in back as well?
Paul
ascheevel
Version: 11.2
Post by ascheevel » Thu Oct 04, 2018 2:39 pm
Second the comment making sure the com add-in is enabled. Sometimes after the add-in gets disabled and we've subsequently re-enabled it, it still doesn't load on excel startup forcing the user to re-enable it each time. When that happens we modify the load behavior of the add-in in the registry to get it loading on excel start again.
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Fri Oct 05, 2018 5:40 am
Thanks.. I have changed the registry behaviour to 3 in regedit then it works perfectly
