I am looking to generate stats by rule to monitor rules statistics - Old vs new rule.
I am currently do not see the }StatsByRule cube in the model-so I enabled }CubeProperties control cube selected the Cube and enter YES for RULE_STATE (ELEMENT)
After that I enabled the start (server) performance monitor and then ran/refresh few cubes.
I am still not able to see the cube }StatsByRule created in under control cube.
I did not restart the server per IBM note below:
Note
RULE_STATS is a dynamic parameter. It does not require a server restart to take effect, but there may be a delay of up to 60 seconds before the property is applied.
Any advise appreciate your help!
RB
}StatsByRule
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
- Excel Version: 2013
Re: }StatsByRule
What version of TM1 are you on? My understanding is that, this feature is available from the initial release of PA (see below link)
http://public.dhe.ibm.com/software/data ... m1_nfg.pdf
