TM1 Web showing Bold
sk1080in
Version: 9.5.1
Post by sk1080in » Fri Jan 12, 2018 12:27 am
I have multiple worksheets in a workbook and all worksheets except one is correctly displaying the values (DBRWS). The issue is everything on the this worksheet is coming bold. I have tried various methods, bolding and unbolding again and updating on tm1 web, however this particular worksheet still shows everything bold. Has anyone seen this issue....Kindly help
Andre_Wium
Excel Version: Excel 2013
Re: TM1 Web showing Bold
Post by Andre_Wium » Fri Jan 12, 2018 6:00 am
Is it a worksheet using an Active Form? If so, have you checked the formatting definitions for that Active Form?
TJMurphy
Version: 10.2.2 64bit
Post by TJMurphy » Sat Jan 13, 2018 11:06 am
If it's not a formatting problem then I wonder if it's http://www.ibm.com/support/docview.wss? ... SS9RXT-_-R?
The heading is : PI91427: TM1 WEB SHOWS IN BOLD SOME LINES OF A WEBSHEET WHILE IN PERSPECTIVES THOSE LINES ARE NOT IN BOLD
Not that there seems to be any detail in there as to a fix unfortunately.
sk1080in
Version: 9.5.1
Post by sk1080in » Mon Jan 15, 2018 1:49 am
Thanks Andre
sk1080in
Version: 9.5.1
Post by sk1080in » Mon Jan 15, 2018 1:51 am
Thanks TJMurphy
