Dimix with non-existing dimension
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Sat Sep 02, 2017 12:13 pm
What do you think ?
I misspelled a dimension name lately in a TI process.
I used the wrong dimension name in a Dimix formula, to check in the metadata tab whether an element is new or not. The Dimix gives 0 as the result. Wouldn't it be an enhancement if it gave an error rather than 0, for dimensions that do not exist ?
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
Version: TM1 10.2.2
Re: Dimix with non-existing dimension
Post by jim wood » Tue Sep 05, 2017 12:18 pm
I'm not sure they'd go for this, after all you can combine it with DimensionExists. I guess you could argue that any of the statements that involve TM1 object checks should have something built in that would react in this kind of way? I wonder if the new coming development interface will cover this?
Jim.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Version: PAL 2.0.8
Post by Wim Gielis » Tue Sep 05, 2017 8:28 pm
Hi Jim,
It would be quite a change (also in other clients next to TI ) and I am also rather confident that IBM won't do this.
Wim
