Creating application items
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Fri Aug 26, 2016 3:56 pm
Wouldn't it be nice to copy a view name (Ctrl-C, C, C, C) and then go to an application folder, do right-mouse button click and choose "Paste as child" ?
Drag-'n-drop a view from the bottom of the list of cubes, all the way to the top of the Server Explorer and you know what I mean ;-)
Bonus points if we can "Paste as Public child".
Wim
https://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
Version: TM1 10.2.2
Re: Creating application items
Post by jim wood » Fri Aug 26, 2016 6:17 pm
I'm really surprised that this one hasn't been dealt with before. Add in that you could have control objects on view and you fin yourself dragging for what seems an eternity only to accidently let go early and do it all again.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Post by lotsaram » Fri Aug 26, 2016 8:08 pm
Wim Gielis wrote:Drag-'n-drop a view from the bottom of the list of cubes, all the way to the top of the Server Explorer and you know what I mean ;-)
You do both know that there is a simple trick to make this less painful?.
- Turn on the properties pane in server explorer
- select the application folder you want to create a shortcut in, the folder contents will be displayed in the properties pane
- in the left hand navigation pane go to whatever cube or view you want and drag it to the right into the properties pane (where the application folder contents still are)
Copy paste would be better but this is at least 10x faster than dragging a view all the way to the top.
Version: PAL 2.0.8
Post by Wim Gielis » Fri Aug 26, 2016 8:26 pm
That is a lot faster, thank you !
Version: TM1 10.2.2
Post by jim wood » Mon Aug 29, 2016 11:52 am
I didn't know that. Thanks Lotsa.
Krystof
Post by Krystof » Fri Sep 23, 2016 10:05 am
Wonderful! Thank you for this trick!
