PA 2.07 - }ClientProperties cube
cgraefe
Post by cgraefe » Tue Apr 14, 2020 11:16 am
i try to find an easy solution to disable client.
In the }ClientProperties dimension in the }ClientProperties cube , I found the element "IsDisabled" which seems to disable a client to login.
My problem is, that this element isn't documented any where.
Can anybody point me to the right documentation?
thanks
Re: PA 2.07 - }ClientProperties cube
Post by lotsaram » Tue Apr 14, 2020 12:59 pm
This property seems to be new and undocumented. That it's undocumented is kinda par for the course given that ReadOnlyUser is also not documented and that has literally been there for ever https://www.ibm.com/support/knowledgece ... 7015d.html
So I wouldn't read anything into it being undocumented. But IsDisabled does seem to be new to the last few 2.0.x releases of PA. I don't recall seeing it before that but I see it is automatically added to clientProperties on all my models runnign on 11.6 and 11.7 builds.
Version: PAL 2.0.8
Post by Wim Gielis » Tue Sep 29, 2020 12:53 am
To use it, set IsDisabled to 1 in the }ClientProperties cube.
Note that you cannot disable a client that is part of the built-in Admin group. The property is ignored in that case.
https://www.wimgielis.com ==> 117 TM1 articles and a lot of custom code
Newest blog article: Avoid circular references https://github.com/wimgielis
macsir
Version: PAL 2.0.9
Post by macsir » Tue Sep 29, 2020 8:30 pm
That is interesting to know. However, this property doesn't seem to work properly at least in 2.0.9.1.
Version: PAL 2.0.8
Post by Wim Gielis » Tue Sep 29, 2020 8:51 pm
I should check my install on the laptop but I’m pretty confident that it is a 2.0.8. I only tested it in TM1 Perspectives.
macsir
Version: PAL 2.0.9
Post by macsir » Wed Sep 30, 2020 8:48 pm
Thanks, Wim.
I tested it as well in Perspectives but not working. Do you need to reboot the server after this change?
What does the TM1 Perspectives say after disabling? How about PAfe and PAW?
Version: PAL 2.0.8
Post by Wim Gielis » Wed Sep 30, 2020 9:07 pm
For me it works. Here are screenshots.
PAL version 11.6.0.14
Version: PAL 2.0.9.4; PAoC 2.0.9.3
Post by gtonkin » Thu Oct 01, 2020 2:11 pm
FWIW, Following Wim's process on PAL 2.0.9.2 (11.8.100.13) gives me the same results as Wim's i.e. Setting disabled to 1 blocks logins.
MarenC
Excel Version: Excel 2016
Post by MarenC » Thu Oct 01, 2020 3:16 pm
Does this affect licencing in any way? I.e. if they are disabled are they counted?
Maren
Version: PAL 2.0.8
Post by Wim Gielis » Thu Oct 01, 2020 3:18 pm
No idea MarenC. But in my generic TI process, I count them separately. Up to the sales colleagues to use the information or not.
I'm planning on rewriting this TI process in tm1py, curious to see how I will advance (or not).
macsir
Version: PAL 2.0.9
Post by macsir » Thu Oct 01, 2020 8:31 pm
Thanks, I am using CAM. Maybe that's the reason?
Version: PAL 2.0.8
Post by Wim Gielis » Thu Oct 01, 2020 10:23 pm
Could be possible, I don't have such an installation for testing.
scrumthing
Version: 11.x
Excel Version: MS365
Post by scrumthing » Fri Oct 02, 2020 8:32 am
AFAIK (remerbing our license audit this year) they are explicitly asking for the isdisabled property because those users are most likely not counted.
Emixam
Post by Emixam » Mon Dec 14, 2020 12:02 pm
I'm also using CAM and it's not working. Is there another easy way to disable a client then ?
Sorry for my English :)
macsir
Version: PAL 2.0.9
Post by macsir » Mon Dec 14, 2020 12:20 pm
I use cam new client parameter and delete the user from }clients dim will disable the user.
Emixam
Post by Emixam » Mon Dec 14, 2020 12:30 pm
Thank you macsir but i'm looking for something more straightforward. I was thinking of something like "if user A is NOT in group X then disable user A".
Emixam
Post by Emixam » Wed Mar 17, 2021 8:44 pm
**Update**
I created a ticket couple months ago and they finally fix the issue with PA 2.0.9.6 release.
PH33540 TM1 server isdisabled flag permits user logins into Planning Analytics server with CAM
https://www.ibm.com/support/pages/syste ... s_2096.pdf
macsir
Version: PAL 2.0.9
Post by macsir » Thu Mar 18, 2021 9:19 pm
Thanks, good to know. :)
