Connect with TM1p.xla & VBA
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.8
Excel Version: Plus 2013
Post by HighKeys » Tue Aug 13, 2019 9:31 am
i'm new with TM1 and i try to get a auto connection in some sheets for TM1.
So i added in the Open Event a check to find out if the user already loaded the plugin, if not then the addon should be loaded.
After that i call the COnnection call from the dll, now you can select a server and press connect.
2 Issues at the moment:
1.) it loads the TM1 Ribbon Addon everytime, even if you already load it.
2.) the Ribbon control is after the connection still disabled like i have never connected to a server
My Open Event:
Private Sub workbook_open()
    Application.Calculation = xlCalculationManual
    'load TM1 add-in if the TM1 menu do not exist
     If Not (bCommandBarExists("TM&1")) Then
     Workbooks.Open ("C:\Program Files\ibm\cognos\tm1_64\bin\tm1p.xla")
     End If
    'hide TM1 toolbars if not in correct team // add MAD to check users
     On Error Resume Next
     With Application
'        .CommandBars("TM1 Servers").Visible = False
'        .CommandBars("TM1 Developer").Visible = False
'        .CommandBars("TM1 Spreading").Visible = False
'        .CommandBars("TM1 Standard").Visible = False
     End With
     On Error GoTo 0
     Application.Run ("NET_CONN")
    'msg = Run("N_CONNECT", "spatpss023.at.dc.eb-grp.net", "Planung")
     If msg <> "" Then
     MsgBox msg
     End If
    Application.Run "TM1RECALC"
End Sub
Function bCommandBarExists(sCmdBarName As String) As Boolean
Dim bCbExists As Boolean
Dim cb As CommandBar
bCbExists = False
 For Each cb In Application.CommandBars
 If cb.Name = sCmdBarName Then
 bCbExists = True
 Exit For
 End If
 Next
bCommandBarExists = bCbExists
End Function
Thanks for your Help
BR
orlando
Version: PAL 2.0.8
Re: Connect with TM1p.xla & VBA
Post by orlando » Tue Aug 13, 2019 1:45 pm
if i have to connect via VBA (what i try to avoid) i use the VBA API:
https://www.bihints.com/tm1_sdk
and this sub
Sub con
hUser = TM1SystemOpen()
AdminHostName = ThisWorkbook.Worksheets("Adr").Range("_adm_1")
ServerName = ThisWorkbook.Worksheets("Adr").Range("_sr_1")
ServerName = Left(ServerName, Len(ServerName) - 1)
'AdminHostServer angeben
Call TM1SystemAdminHostSet(hUser, AdminHostName)
ServerCount = TM1SystemServerNof(hUser)
'Einen ValuePool-Handle erstellen
hPool = TM1ValPoolCreate(hUser)
MsgBox AdminHostName + " " + ServerName + " " + UserName + " " + Password
vServerName = TM1ValString(hPool, Trim(ServerName), 0)
vClientName = TM1ValString(hPool, Trim(UserName), 0)
vClientPassword = TM1ValString(hPool, Trim(Password), 0)
'Am TM1-Server anmelden
hServer = TM1SystemServerConnect(hPool, vServerName, vClientName, vClientPassword)
End Sub
maybe this will help
HighKeys
Post by HighKeys » Fri Aug 16, 2019 8:25 am
thanks for your help!
But could you help me also how i can check if the Ribbon is loaded or not?
I Tried this
bCbExists = False
 Debug.Print cb.Name
 Debug.Print cb.Parent.Name
 bCbExists = True
 Exit For
 End If
 Next
End Function
And i Search for "TM&1" but i can't find the ribbon, even when its loaded.
Any idea whats wrong?
orlando
Version: PAL 2.0.8
Post by orlando » Mon Aug 19, 2019 8:37 am
i would check, if the XLA is loaded.
Somethink like that schould help
http://www.office-loesung.de/ftopic30774_0_0_asc.php
Best regards
orlando
HighKeys
Post by HighKeys » Tue Aug 20, 2019 12:39 pm
Hi!
works perfect, thank you so much!!
So one last thing to do, how i could check if TM1 is already connected to a Server?
Thanks!
orlando
Version: PAL 2.0.8
Post by orlando » Tue Aug 20, 2019 2:05 pm
i would play with the TM1User in Excel
https://www.ibm.com/support/knowledgece ... 1user.html
if empty - not connected. If not empty - connected.
best regards
orlando
HighKeys
Post by HighKeys » Wed Aug 21, 2019 10:20 am
Hey Orlando!
Thanks for your help! Works great now!
if someone is interested, here is the code:
Dim oAddIN As AddIn, vAd As String
    On Error GoTo Fehler
    For Each oAddIN In Application.AddIns
    If oAddIN.Name = "tm1p.xla" Then
    If oAddIN.Installed = False Then vAd = oAddIN.FullName
    Exit For
    End If
    Next oAddIN
    If Len(vAd) <> 0 Then Application.AddIns.Add(vAd).Installed = True
        GoTo Ende
Fehler:
Ende:
    If Application.Run("TM1User", "SERVERNAME") = "" Then
    End If
    Do While Application.Run("TM1User", "SERVERNAME") = ""
        DoEvents
    Loop
End Sub
BR
HighKeys
