Single Sign On problem
AskAndAnswer
Version: 2.0...
Post by AskAndAnswer » Fri May 17, 2019 12:24 am
I am trying to set up SSO in Planning Analytics 2.0.6 and Cognos 11.0.12, security mode 5. I can use CAM to login, and it works without issues in all applications. The problem is particularly SSO, I am always prompted for user id and password. In Architect if I login once, then log out and login again within the same session, the second time user ID and password won't be requested. If I reopen Architect, it will require credentials again.
IE is set to Automatic logon in all zones.
SinglSignonOption is set in the namespace advanced properties.
Any ideas?
Thank you.
