Using old clients with new planning analytics server
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 1:52 pm
Hi we are having client 10.1 and planning to connect with new planning analytics server . is this compatible and possible to use the old client with the new server . If anyone has achieved this please let us know .
Admin : see the linked post in this thread for the important post in this thread http://www.tm1forum.com/viewtopic.php?f ... 785#p68776
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Using old clients with new planning analytics server
Post by Elessar » Tue Feb 20, 2018 2:57 pm
Hello! What do you mean by "client"? Architect, Perspectives, CAFE, Perf. Modeler, Cognos Insight?
Usually, you can connect using old clients to new server, but you should turn ON supportpretlsv12clients parameter in tm1s.cfg: http://www-01.ibm.com/support/docview.w ... wg27048181
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 3:23 pm
Yes we want architecture to connect . We are in 10.1 and trying to connect to IBM Planning Analytics .
I have added the entry in the config file
SupportPreTLSv12Clients=T and restarted the server .
But the server shows up but we could not login to it .
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar » Tue Feb 20, 2018 3:50 pm
What do you mean by "could not login"? The login window did not appear? Are there any errors?
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 4:02 pm
we see the server on double clicking on the server nothing happens, Will not show me the login credentials to enter or log me in through integrated login . But it works with the new client .
I alos have additional parameter IPAddress= T
in the config files.
ykud
Post by ykud » Wed Feb 21, 2018 6:31 am
I think PAL and TM1 10.x use different security certificates, can you check the versions / sizes of applix.ca file in bin64/ssl folder for PA and 10.1 client?
Difference in ssl certs would look exactly as you describe (see the server, cannot connect). You can enable the Login logging in tm1 server to see whether there's a SSL handshake issue.
Y
mberson
OLAP Product: Tm1
Version: 9.5.1
Post by mberson » Thu Mar 22, 2018 2:10 pm
Having this same experience as well. We often use the older version of Perspectives/Architect to connect to the new and old version of servers during an upgrade project. We opened a ticket with IBM and they stated that Perspectives/Architect 10.1.x and 10.2.x will not be able to connect to PA Local 2.0.x whc.
Haven't looked into the SSL certs yet, but that does make sense.
Any other feedback on this?
Matthew Berson
ACG TM1 Consulting
qml
Excel Version: 2007 - 2016
Post by qml » Fri Mar 23, 2018 5:34 pm
We have a PAL 2.0.4 server and our users are using a multitude of Perspective/Architect versions, going back as far as version 9.5.1. Here are the things that need to be done:
1) set the TM1 Admin server to support pre-TLS v1.2 clients via Cognos Configuration
2) add in tm1s.cfg:
SSLCertificateID=TM1Server
SSLCertAuthority=ibmtm1.arm
3) copy ibmtm1.arm file from PA2 installed directory to bin/ssl and bin64/ssl folders of Perspectives/Architect installation (or, really, anywhere else on the client machine or a network share accessible from it)
4) change in TM1 Options in Perspectives/Architect:
Certicate Authority: full path to the copied ibmtm1.arm file
CertificateID: TM1Server (case-sensitive)
Kamil Arendt
Post by tomok » Sun Mar 25, 2018 12:23 pm
2) add in tm1s.cfg:
Can I recommend we put this post in the Tips and Tricks section? Great info, thanks.
macsir
Version: PAL 2.0.8
Post by macsir » Sun Mar 25, 2018 10:50 pm
2) add in tm1s.cfg:
Brilliant! Thanks for sharing. I got it working on my current 10.2.2 fp4 client to connect to PA2 server by changing the configurations above. Just need to remember to reboot your admin host after changing in Cognos Configuration.
A quick Q, is there any difference between the old client of V10 and PA client when connecting to PA2 server? Especially from end user point of view?
Post by lotsaram » Mon Mar 26, 2018 12:29 pm
Paul Segal
Version: TM1 11 and up
Post by Paul Segal » Tue May 08, 2018 1:29 pm
Just in case anyone else goes down the same rabbit hole:
Step 3 on Kamil's post implies (or at least it did to me) that you don't need to add the ibmtm1.arm file to the local install \ssl directory. Using 10.2 and 10.2.2 it wouldn't work for me unless that file is in the \ssl directory, no matter which directory I pointed the SSL Certificate Authority to.
Paul
qml
Post by qml » Mon May 14, 2018 2:04 pm
Hi Paul, that is interesting. My post was indeed meant to imply that you don't need to put the file in the ssl directory. In newer Windows versions Program Files is locked down and you'd need admin access to put any files in there, which is often not possible. In all my testing simply linking to an external, network share holding ibmtm1.arm worked without having to put the file in the ssl folder.
Can you tell me more about your setup? Is it only Architect/Perspectives? Are you using any VBA or any other custom stuff?
Kamil Arendt
Paul Segal
Post by Paul Segal » Mon May 14, 2018 2:29 pm
Hi Kamil,
The only non-vanilla thing is that this is running on Citrix, and the way this is set up I don't have access to the \ssl directory for the Citrix image to add the imbtm1.arm file. It is only Architect/Perspectives for the moment. I tried it on a local copy of TM1 and I had the same issue. Clients are 10.2 and 10.2.2. The only way I could get this to work was to set UseSSL=F on the server, and then the TM1 server instances are visible and I'm able to log in. If I don't do this, the instances are visible, but I get the hour glass and no login pop-up.
Paul
Catherine
Version: 10.2.2 - PA
Post by Catherine » Tue Mar 12, 2019 10:36 am
2) add in tm1s.cfg:
Thank you very much, it worked perfectly well for me.
But I have a question. Once I have done the step 4, I see my instances that are migrated to Planning Analytics. But I don't see any more 10.2.2 instances that are not migrated yet. Is there a way to see at the same time PA instances, and 10.2.2 instances ?
Thanks in advance
qml
Post by qml » Fri Mar 15, 2019 4:28 pm
Hi Catherine,
Yes, you will need to change all the TM1 Options settings you changed in step 4 back to the original ones and you will then see the 10.2.2 servers. So you can't access both versions at the same time - you'll have to keep flipping your settings I'm afraid.
Kamil Arendt
mfritsche
Version: 2.0.6
Post by mfritsche » Wed Oct 16, 2019 7:08 am
Greetings,
while connecting to a TM1 server (PA 2.0.8) with a TM1 client (PA 2.0.6) is possible, is this a constellation supported by IBM?
