Tip of the Day - Ctrl+N and MDX
Version: 10.2.2., PAW
Post by Steve Rowe » Fri Mar 03, 2017 11:52 am
In the current perspectives subset editor if you select elements and do ctrl+n and then ctrl+v you get the MDX references for the elements selected.
Can come in pretty handy.
You can thank my bad tping for this tip!
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Re: Tip of the Day - Ctrl+N and MDX
Post by Wim Gielis » Sat Mar 11, 2017 8:59 am
Thanks!
Indeed, we can reference elements in a dimension like that.
{[dimension].[element]}
The part in the middle is the result of ctrl-n, ctrl-v.
I have seen people using TM1SubsetAll, Hierarchize, TM1FilterByLevel, TM1FilterByPattern on the exact same element string without wildcards, just to end up with the same 1 element :shock: :D
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Active form claustrophobia
rafaewolie
OLAP Product: IBM Cognos TM1
Version: TM1 PA 2.0
Excel Version: Excel 2013
Post by rafaewolie » Wed Sep 06, 2017 6:32 pm
Very Usefull, thanks for the tip
