Dynamic Datasource Path
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: Dynamic Datasource Path
Post by jim wood » Thu Sep 01, 2016 12:29 pm
I've just gone through this. I can't remember where I was at the time but I do know I'm no hurry to go back. It's ironic that I'm now at a government agency and the security policies are no where near as tight inside the IT department.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Hector2005
OLAP Product: MOLAP
Post by Hector2005 » Thu Jul 19, 2018 9:05 am
Hello Guys,
I have a problem to assign the file path in runtime.
I have made a ti process and select the type is File then assigned a template Excel file "Just contained a header" I attached it.
after that I opened the prolog tab : and wrote the following.
DataSourceNameForServer = 'C:\Program Files\ibm\cognos\tm1_64\samples\tm1\Test\Templates\ProductionData.xlsx';
In the Data tab: I wrote the following as you see Just a simple code to check if it's okay or not.
Version = 'Plan';
IF(Accounts @<> 'Accounts' );
	IF(DimIx('ProductionDim', Accounts) > 0);
		CellPutN(Year1/12, 'Production','Jan 2018' , Accounts, Version);
	ENDIF;
ENDIF;
If this doing well I will make a cube then put all my paths in it.
But, Unfortunately it doesn't work. Is there anything I missed ???
Thanks in advance,
Best Regrads.
File I want to Load.JPG (62.15 KiB) Viewed 602 times
Post by declanr » Thu Jul 19, 2018 10:00 am
TIs don’t accept xls or xlsx etc rules as a source, it needs a flat file to read (CSV, CMA, TXT etc.)
I believe performance modeller could accept excel files but I think that just had an additional program that converted it to a CSV first, you can do something similar yourself by having VBS executed in the prolog to convert the xlsx to a CSV and then set the CSV as your data source.
Hector2005
OLAP Product: MOLAP
Re: Dynamic Datasource Path1
Post by Hector2005 » Fri Jul 20, 2018 2:17 am
Appreciated sir, You are right it worked.
Really this is amazing community, Because everyone helps the others. :) :)
Thanks a lot,
Best Regards.
