Another TM1 TOP
Ricky Marwan
Version: 9.4
Another TM1 TOP
Post by Ricky Marwan » Thu Sep 27, 2012 11:08 am
Monitor client(s) activities and Message Log at the same time.
TM1 Server Monitor
tm1 server monitor.jpg (110.93 KiB) Viewed 16593 times
Compatible TM1 Version(s):
TM1 9.5.2
TM1 10.1
Features:
1. Log activities
2. Open log directly from app
3. Broadcast message
4. Cancel Thread
5. Disconnect Client
6. Send Message
7. Auto connect
8. Monitor Message Log
Requirements:
.Net Framework 4
How to Setup:
TM1 Server Monitor - User Guide.pdf
User Guide
(430.96 KiB) Downloaded 1169 times
TM1 Server Monitor 1.1.rar
(331.47 KiB) Downloaded 739 times
TM1 Server Monitor 1.1.zip
TM1 Server Monitor 1.1 (ZIP)
(746.05 KiB) Downloaded 912 times
Ricky Marwan
JDLove
Re: Another TM1 TOP
Post by JDLove » Thu Sep 27, 2012 2:26 pm
Hi Ricky,
Installed ok
W7
TM1 10.1
Thanks for that !
Olivier
Version: Tm1 9.4MR1 FP3 HF12
Excel Version: Excel 2003
Re: Another TM1 TOP
Post by Olivier » Fri Sep 28, 2012 5:25 am
Nice and easy to get up and running, tested with 9.4MR1 FP3.
HTH
Olivier
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Re: Another TM1 TOP
Post by Harvey » Mon Oct 01, 2012 12:17 am
Nice work, Ricky! This looks really nice.
Flow OLAP - thinking outside the cube.
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Mon Oct 01, 2012 11:16 am
Updated Version 1.0.1
- View log in Excel for easy analysis, filters etc.
- Allow to refresh connection when unavailable without closing tab
Ricky Marwan
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Fri Oct 05, 2012 10:57 am
Updated Version 1.0.2
- Auto connect to server(s) at startup (app)
- Reconnect button shown if connection unavailable
Ricky Marwan
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Wed Oct 10, 2012 4:39 am
Updated Version 1.1
- Monitor TM1 Server Message Log
Ricky Marwan
iansdigby
Version: 9 + 10 + Plan An
Excel Version: All
Re: Another TM1 TOP
Post by iansdigby » Wed Nov 07, 2012 4:11 pm
Probably the best thing since sliced bread.
Thank you.
Steve Vincent
Version: 10.2.2 FP1
Re: Another TM1 TOP
Post by Steve Vincent » Tue Jan 29, 2013 1:41 pm
for people who can't expand RAR files i have just updated the original post with a ZIP version too
sleepyEDB
Version: 10.1.1
Excel Version: Excel 2010
Re: Another TM1 TOP
Post by sleepyEDB » Fri Feb 15, 2013 3:35 pm
A most excellent tool...thank you very much!
sleepy
Steve Vincent
Version: 10.2.2 FP1
Re: Another TM1 TOP
Post by Steve Vincent » Wed Mar 06, 2013 8:54 am
I'm having an issue where the program crashes on start up. I suspect it's a bug related to the number of services i asked it to load on start up (4, i think) but i don't know where its storing the start up config. Is there any way to edit that manually to get the program working again?
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Thu Mar 07, 2013 2:58 am
Steve,
Thanks for the feedback, will fix the bug soon.
the settings file is located in (Win XP):
C:\Documents and Settings\<user>\Application Data\TM1 Server Monitor
you may delete the file.
cheers
Ricky Marwan
Steve Vincent
Version: 10.2.2 FP1
Re: Another TM1 TOP
Post by Steve Vincent » Thu Mar 07, 2013 1:07 pm
Superb, thank you. I can confirm i had 4 services listed, i just altered the flag of one to "<AutoConnect>false</AutoConnect>" and it's loaded just fine. It also autoloaded the service i flagged as false, which may point you to where the bug is :)
Paul Segal
Version: TM1 11 and up
Re: Another TM1 TOP
Post by Paul Segal » Thu Mar 07, 2013 2:00 pm
I've been meaning to post about this - I've had the same problem, just to confirm what Steve is saying.
Paul
show75
OLAP Product: oracle and sql server
Version: TM1 9
Re: Another TM1 TOP
Post by show75 » Wed Mar 13, 2013 9:23 pm
I need your help i use tm 9 and tm1top but i can not do any dthing when this massege come "object duplicate" and i can not kill or stop this thing so i need your help please
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Thu Mar 14, 2013 2:28 am
show75,
are you reporting bug? if so, provide me a screenshot of the error please.
check this out http://www.tm1forum.com/viewtopic.php?p=9378
Ricky Marwan
ppos
Re: Another TM1 TOP
Post by ppos » Fri Mar 15, 2013 3:38 pm
Hello Ricky,
Your tool is really great but as I assume there is no way to "verify admin access" if TM1 server uses CAM authentication. Are you planning to add such functionality?
Kindes regards
Pawel
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Sat Mar 16, 2013 11:28 am
Hi Pawel,
I plan to have all security type, but currently i don't have TM1 server configured with CAM security.
I can add function to verify CAM easily, but for sure i need to test it myself before releasing the tool.
If you keen to help, i can give you the tool compiled with CAM for you to test, email me if you interested.
Ricky Marwan
Ricky Marwan
Version: 9.4
Re: Another TM1 TOP
Post by Ricky Marwan » Wed Mar 20, 2013 8:21 am
New Version, build using Qt no .Net Framework required
If TM1 installed other than C:\Program Files\Cognos\TM1 add your TM1 bin directory to PATH environment variables or copy executable and related dlls into TM1 bin folder
download here:
http://sdrv.ms/16KJzuI
Note:
For those using CAM, the program won't check whether supplied user has ADMIN group assigned.
Ricky Marwan
Paul Segal
Re: Another TM1 TOP
Post by Paul Segal » Wed Mar 20, 2013 8:49 am
Excellent job Ricky - this looks and feels really good. I'll give it a soak test on four servers for a day or two and let you know how it does.
Paul
