Dimension utilisation - finding redundant dimensions
Martin Ryan
Post by Martin Ryan » Wed May 04, 2011 2:25 am
The attached TI process will cycle through the list of dimensions and find out which cubes they are used in. If a dimension is not used then it puts out "-" in the cube column. This can help you identify which dimensions are no longer being used.
Info_DimensionUtilisation.pro
(2.56 KiB) Downloaded 1749 times
Jodi Ryan Family Lawyer
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: Dimension utilisation - finding redundant dimensions
Post by jim wood » Wed May 04, 2011 12:30 pm
Very handy indeed.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Kyro
OLAP Product: MODLR - The CPM Cloud
Version: Always the latest.
Excel Version: 365
Post by Kyro » Mon Jul 18, 2011 7:26 am
Brilliant! thanks for this.
LoganNSE
Version: 9.5.2
Excel Version: 2003 2007
Post by LoganNSE » Tue Nov 22, 2011 10:55 am
Excellent!! Thanks for the code. :idea:
Logan
tosca1978
Version: 9.5.2
Post by tosca1978 » Thu Apr 12, 2012 6:42 pm
Hi Martyn,
I can't seem to open the attachment once it is downloaded? It asks me to search the net for an appropriate program to open the file. Can you tell me how to open using TM1?
Excel Version: 2010 and 2016
Post by Alan Kirk » Thu Apr 12, 2012 7:42 pm
tosca1978 wrote:Hi Martyn,
I'll save "Martyn" (sic) some typing.
It's a TI Process (.pro) file. You don't open it (though you can using Notepad if you want to see what's in it first), you put it into your data directory so that the server can register the process the next time it restarts.
tosca1978
Version: 9.5.2
Post by tosca1978 » Fri Apr 13, 2012 5:28 am
Martin - apologies for the typo and many thanks for the TI - it's exactly what I wanted.
Alan - many thanks for pointing out what I needed to do - much appreciated.
tosca1978
Version: 9.5.2
Post by tosca1978 » Fri Apr 13, 2012 5:48 am
Hi Martin - sorry another question!
Is there anyway of establishing if a dimension (and cube for that matter) is referenced in any rules or TI's? I have a few dimensions in my model which are not used in any cubes but are referenced in some rules. As I inherited this model from another developer (with no technical documentation) I am pretty nervous about deleting dimensions and cubes although the model definitely needs tidying up!
Martin Ryan
Post by Martin Ryan » Mon Apr 16, 2012 8:05 am
There are some clever documentation tools out there somewhere but you could also use the TM1 tools add-in which probably give you want you need more quickly. The specific tool you're after is described...
- The ability to load text files (including .pro and .rux files) into an excel workbook and then search them for a specified text expression. This can help determine the TI processes or rules which affect a specified cube.
As well as searching for cube references using this functionality you can search for dimension names. Or any text at all.
Martin
Version: PAL 2.0.8
Post by Wim Gielis » Mon Apr 16, 2012 2:50 pm
tosca1978 wrote:Hi Martin - sorry another question!
Alternatively, you could use tools like Notepad++ to search in several files and folders. Also, regex and other features.
http://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
rogovem
OLAP Product: TM1, BI
Post by rogovem » Thu Feb 14, 2013 1:49 pm
Hi Martin,
is it possible to make finding the cubes for two dimensions?
Egor.
Martin Ryan
Post by Martin Ryan » Fri Feb 15, 2013 1:46 am
Hi Egor,
I'm not entirely sure I follow your question but if you're asking whether you can check on just two specific dimensions then there are two approaches. The easiest one is to look at the extract file and just hide/delete all the dimensions you're not interested in.
The other option is to add a line like the one below, which will skip any dimension except 'Dimension1' and 'Dimension2';
if(sDim@='Dimension1' % sDim@='DImension2', 0, itemskip);
If that's not what you're asking could you try rephrasing your question?
Martin
rogovem
Post by rogovem » Fri Feb 15, 2013 6:53 am
Hi Martin!
sorry for the wrong question.
I had in mind is to figure out a full set of cubes that uses two particular dimensions at the same time.
Perhaps these examples will help to explain what I mean:
asciioutput(exportFile, sDim1, sDim2, sCubeName);
Egor.
Martin Ryan
Post by Martin Ryan » Mon Feb 18, 2013 9:54 pm
Ok, I see what you're trying to achieve. This particular process wouldn't do it. Here's how I'd probably do that
- Create a new process
- Use the All subset of the }Cubes dimension as the TI source
- Set the variable to be called sCubeName;
- In the Prolog tab have something like
keyDim1='MyDim1';
keyDim2='MyDim2';
sFile='C:\myfile.csv';
- in the Data tab have something like
nKeyDimCount=0;
# cycle through the dimensions in the current cube
j=0;
while(j<40);
  j=j+1;
  tDim=tabDim(sCubeName, j);
  if(tDim@=keyDim1 % tDim@=keyDim2);
    nKeyDimCount=nKeyDimCount+1;
  endif;
end;
if(nKeyDimCount=2);
  asciioutput(sFile, sCubeName, 'Has both key dimensions');
endif;
Hopefully that'll point you in the right direction. You can do whatever tweaks you need within that if statement.
Martin
rogovem
Post by rogovem » Tue Feb 19, 2013 9:50 am
Hi Matin!
This is exactly what I had in mind.
it works great!
I think that I could not do it myself.
You have helped me incredibly.
Thank you a lot!
Egor.
ldwnt
Version: 10.1.1
Post by ldwnt » Tue May 07, 2013 5:33 am
Martin Ryan wrote:The attached TI process will cycle through the list of dimensions and find out which cubes they are used in. If a dimension is not used then it puts out "-" in the cube column. This can help you identify which dimensions are no longer being used.
Thanks for the process example. But I notice that a variable 'j' is used to go through all dimensions in a cube & it's assumed to be less than 20. I wonder if there's any way to find out the exact number of dimensions associated with a cube in TI?
Post by lotsaram » Tue May 07, 2013 6:50 am
ldwnt wrote:I wonder if there's any way to find out the exact number of dimensions associated with a cube in TI?
You just make the while condition check for the result of the tabdim function (returns a blank string if the dimension index argument is a number greater than dimensions in the cube).
i=1;
While( TabDim(sCubeName, i) @<> '' );
  sDimName = TabDim(sCubeName, i);
  i = i + 1;
End;
.. at the end of the loop number of dimensions in the cube = i - 1
ldwnt
Version: 10.1.1
Post by ldwnt » Wed May 08, 2013 2:45 am
i=1;
  i = i + 1;
End;
It works. Thank you. It would be more convenient if TI provided a single function~
rmackenzie
Post by rmackenzie » Wed May 08, 2013 5:04 am
Sometimes it is useful to know the number of dimensions in the largest cube in the server (by dimension size). This snippet extends on Lotsa's code to give that answer. I also amended it to only make the call to TABDIM once, and use a continue flag instead, as IMHO this is slightly more efficient:
# minimum 2 dimensions in a cube
nMaxNumberOfDimensions = 2;
# iterate cubes
nCubeCounter = 1;
nMaxCubes = DIMSIZ ( '}Cubes' );
WHILE ( nCubeCounter <= nMaxCubes );
  sCubeName = DIMNM ( '}Cubes', nCubeCounter );
  # iterate cube dimensions
  nDimCounter = 1;
  nContinue = 1;
  WHILE ( nContinue = 1 );
    sDimName = TABDIM ( sCubeName, nDimCounter );
    IF ( sDimName @= '' );
      nContinue = 0;
    ELSE;
      nDimCounter = nDimCounter + 1;
    ENDIF;
  END;
  # subtract 1 from nDimCounter
  nDimCounter = nDimCounter - 1;
  # update max dims if less than dimcounter
  IF ( nMaxNumberOfDimensions < nDimCounter );
    nMaxNumberOfDimensions = nDimCounter;
  ENDIF;
  # do next cube
  nCubeCounter = nCubeCounter + 1;
END;
# pass to log
ItemReject ( 'Largest cube has ' | NumberToString ( nMaxNumberOfDimensions ) | ' dimensions' );
Robin Mackenzie
Jorge Rachid
Post by Jorge Rachid » Wed Mar 29, 2017 3:08 pm
I am trying to use this process but I am facing an error on .cma file.
What I have to do in this case about the exportfile folder on prolog?
Tks,
JR
