Free Excel-to-Text converter
bunchukokoy
OLAP Product: IBM Cognos TM1
Version: 10.2.2.x
Post by bunchukokoy » Mon May 20, 2013 9:48 am
Guys,
:) . Again.
Just happened to need a utility, that my TM1 can use to convert Excel files into Text files. Is there anyone who would want to share. :)
We used one before, that was from my prev company. And ommits decimal places.
Anyone who'd like to share. :mrgreen:
Thanks very much,
Bunchukokoy
rmackenzie
Re: Free Excel-to-Text converter
Post by rmackenzie » Mon May 20, 2013 10:26 am
File -> Save As -> Text (Tab delimited) (*.txt)
Is that what you're looking for?
Robin Mackenzie
bunchukokoy
Version: 10.2.2.x
Post by bunchukokoy » Mon May 20, 2013 10:29 am
Yes Mackenzie. But I'm looking for a VB script or a like, which can be executed by a TI.
rmackenzie
Post by rmackenzie » Mon May 20, 2013 11:05 am
Option Explicit
'variables
Dim objXl, objWb
'automate excel
Set objXl = CreateObject("Excel.Application")
'open and save as text
Set objWb = objXl.Workbooks.Open("D:\DVD List.xlsx")
objWb.SaveAs "D:\DVD List.txt", -4158
'close wb
objWb.Close (False)
'quit excel
objXl.Quit
'clean up
Set objWb = Nothing
Set objXl = Nothing
Robin Mackenzie
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Mon May 20, 2013 12:09 pm
If you want to use With...End With construct instead of (object) variables:
With CreateObject("Excel.Application")
  With .Workbooks.Open("D:\file.xlsx")
      .SaveAs "D:\file.txt", -4158
      .Close 0
  End With
  .Quit
End With
https://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Updating process line numbers with AutoHotKey
rmackenzie
Post by rmackenzie » Tue May 21, 2013 3:27 am
Wim Gielis wrote:If you want to use With...End With construct instead of (object) variables:
Wim - good suggestion. So the complete script would read:
Option Explicit
'constant for text file
Const xlCurrentPlatformText = -4158
'variables
Dim strInputExcelFile, strOutputTextFile
'retrieve and validate inputs
With WScript
  If .Arguments.Count <> 2 Then
    .Echo "Missing arguments"
    .Quit
  Else
    strInputExcelFile = .Arguments(0)
    strOutputTextFile = .Arguments(1)
  End If
End With
'perform save as tab delimited text
  With .Workbooks.Open(strInputExcelFile)
    .SaveAs strOutputTextFile, xlCurrentPlatformText
    .Close 0
  End With
  .Quit
End With
And can be called from TI by:
sCommand = 'cscript.exe "c:\yourscripts\convert.vbs" "c:\yourexcel\sheet.xlsx" "c:\yourtext\converted.txt"';
ExecuteCommand ( sCommand, 1 );
Robin Mackenzie
Version: PAL 2.0.8
Post by Wim Gielis » Tue May 21, 2013 7:22 am
Robin, that's neat code, thanks !
bunchukokoy
Version: 10.2.2.x
Post by bunchukokoy » Tue May 21, 2013 3:11 pm
Mackenzie and Wim, thank you very much for all the replies. I really appreciate your generosity. :)
PowerDim
Version: PA 2.0.8
Excel Version: Excel 2016
Post by PowerDim » Thu Sep 10, 2020 2:48 pm
Mackenzie, Wim, it's really works! Thank you!
Could you help with one more thing?
Is it possible to add such lines of the script so that the cell format is cleared before saving the file?
Dmitry
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 10, 2020 3:00 pm
Did you try this yourself for 5 minutes in the macro recorder of Excel VBA, to generate the syntax ?
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 10, 2020 3:01 pm
For example, see line 2:
    .Worksheets(1).UsedRange.NumberFormat = "General"
    .Close 0
  End With
PowerDim
Version: PA 2.0.8
Post by PowerDim » Thu Sep 10, 2020 3:46 pm
Wim, thank you so much!
Sorry, I followed the difficult path and completely forgot about the simple)
Everything works!
While I was setting up the script, I got the idea to abandon this script file and write everything through the ti-process? Is it possible to run a script using ExecuteCommands without calling the vbs-file? In this case, TI-process will be self-sufficient and not depend on the presence of a file with a script.
Perhaps you have any ideas?
Dmitry
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 10, 2020 4:01 pm
Then I would suggest AsciiOutput in the Prolog tab to a text file and execute it in the Epilog tab.
PowerDim
Version: PA 2.0.8
Post by PowerDim » Thu Sep 10, 2020 6:09 pm
Yes, that's a good idea.
But the file with VBscript is unloaded with the text in quotes.
I tried closing quotes both at the beginning and at the end. Unfortunately, such a file does not work.
Script, which not working:
Option Explicit
With WScript
    .Echo "Missing_parameters"
    .Quit
  Else
  End If
End With
    .Close 0
  End With
  .Quit
End With
When I manually remove the quotes or use the prepared file with this script, it works fine.
TI-code:
sScript = '
' | Char(10) | '
Option Explicit
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
With WScript
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
    .Quit
' | Char(10) | '
  Else
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
  End If
' | Char(10) | '
End With
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
' | Char(10) | '
    .Close 0
' | Char(10) | '
  End With
' | Char(10) | '
  .Quit
' | Char(10) | '
End With
' | Char(10) | '
ASCIIOutput(csScriptPath, sScript);
Maybe you have an opportunity to suggest what can be fixed in this situation?
Dmitry
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 10, 2020 6:16 pm
I would do AsciiOutput for every line, rather than 1 ridicously long string with difficult concatenations.
Emixam
Post by Emixam » Thu Sep 10, 2020 6:36 pm
I agree. I usually do something like this. It's clean and easily reusable.
# Define lines
sLine1  = 'This is the first line of your output';
sLine2  = '';
sLine3  = 'This is the third line';
sLine4  = '';
sLine5  = 'and so on !';
sLine6  = '';
sLine7  = '';
sLine8  = '';
sLine9  = '';
sLine10 = '';
sLine11 = '';
sLine12 = '';
sLine13 = '';
sLine14 = '';
sLine15 = '';
sLine16 = '';
sLine17 = '';
sLine18 = '';
sLine19 = '';
sLine20 = '';
# Use a loop to generate the AsciiOutput (Change nMax if needed)
k = 1;
nMax = 20;
sStaticString = 'sLine';
While( k <= nMax );
	sCurrentLine = Expand( '%' | sStaticString | NumberToString( k ) |  '%' );
	AsciiOutput( sFileName, sCurrentLine );
	k = k + 1;
END;
Also, you might want to use DatasourceASCIIQuoteCharacter in your TI:
DatasourceASCIIQuoteCharacter = '';
Sorry for my English :)
Version: PAL 2.0.8
Post by Wim Gielis » Thu Sep 10, 2020 6:39 pm
I don't fancy numbering lines, but I do understand for the loop and Expand to work.
Rather, I would just repeat the AsciiOutput and wrap the text within such a function call.
paulsimon
Version: PA 2.0.5
Post by paulsimon » Thu Sep 10, 2020 8:34 pm
I think I hit a similar problem with the quotes recently.
I traced the problem to the fact that when you output a string from textoutput/asciioutput it will always enclose that string in double quotes so if you put double quotes around every bit of text it doesn't work. The answer is just to omit the first and last double quote and let the asciioutput put them in
Post by lotsaram » Thu Sep 10, 2020 9:06 pm
Or just set the quote character to empty string.
PowerDim
Version: PA 2.0.8
Post by PowerDim » Thu Sep 10, 2020 10:05 pm
Dear community, thank you so much for your help!
As a result, I got the following TI code and it works fine for me at this moment.
This code will be supplemented in the part of overriding the source files for processing, but the main point is below.
Maybe later I can update this post and add a more complete version of this TI-process.
SOURCE - None
PARAMETERS - None
PROLOG
#*** Prolog: Start
#<description etc.>
### Constants
csFolder = <...YOUR_FOLDER...>;
csScriptAppPath = 'C:\Windows\System32\cscript.exe';
csScriptName = 'ConvertExcelToTXT.vbs';
csScriptPath = csFolder | csScriptName;
### Config ASCIIOutput (for removing quotes from ascii-file with script)
### Create VB-Script (*.vbs)
# Define lines
sLine1  = 'Option Explicit';
sLine2  = 'Const xlCurrentPlatformText = -4158';
sLine3  = 'Dim strInputExcelFile, strOutputTextFile';
sLine4  = 'With WScript';
sLine5  = '  If .Arguments.Count <> 2 Then';
sLine6  = '    .Echo "Missing_parameters"';
sLine7  = '    .Quit';
sLine8  = '  Else';
sLine9 = '    strInputExcelFile = .Arguments(0)';
sLine10 = '    strOutputTextFile = .Arguments(1)';
sLine11 = '  End If';
sLine12 = 'End With';
sLine13 = 'With CreateObject("Excel.Application")';
sLine14 = '  With .Workbooks.Open(strInputExcelFile)';
sLine15 = '    .Worksheets(1).UsedRange.NumberFormat = "General"';
sLine16 = '    .SaveAs strOutputTextFile, xlCurrentPlatformText';
sLine17 = '    .Close 0';
sLine18 = '  End With';
sLine19 = '  .Quit';
sLine20 = 'End With';
# Generate the ASCIIOutput (check "nMaxLines")
i = 1;
nMaxLines = 20;
sLineCaption = 'sLine';
While( i <= nMaxLines );
	sCurrentLine = Expand( '%' | sLineCaption | NumberToString( i ) |  '%' );
	ASCIIOutput(csScriptPath, sCurrentLine);
	i = i + 1;
END;
#*** Prolog: End
EPILOG
#*** Epilog: Start
sFileName = <...YOUR_FILE...>;
sFileFormat = '.xlsx';
sFullFileName = sFileName | sFileFormat;
sFilePath = csFolder | sFullFileName;
sExportFilePostfix = '_Exported';
sExportFileName = sFileName | sExportFilePostfix;
sExportFileFormat = '.txt';
sExportFullFileName = sExportFileName | sExportFileFormat;
sExportFilePath = csFolder | sExportFullFileName;
sCommand = csScriptAppPath | ' "'| csScriptPath | '" "'| sFilePath |'" "' | sExportFilePath |'"';
ExecuteCommand(sCommand, 1);
ASCIIDelete(csScriptPath);
#*** Epilog: End
Dmitry
