Is there an easy way to convert a dynamic subset to static?
ChrisF79
OLAP Product: IBM TM1
Version: 9.5.1
Excel Version: 2007 SP2
Post by ChrisF79 » Fri Mar 16, 2012 1:10 pm
We have some problems going on due to dynamic subsets causing table locks, etc. That's not the point of the post though. The point is, how can we easily convert dynamic subsets to static ones? I've read about the SubsetCreateByMDX function but that creates the dynamic subset. Any way of making it static after the fact?
Re: Is there an easy way to convert a dynamic subset to stat
Post by declanr » Fri Mar 16, 2012 1:23 pm
You could have a TI that uses the MDX generated subset as its datasource and simply adds the elements to a new subset.
If you need the subset to have the same name as the MDX generated one you will just need to think about the order of your actions... e.g. when to delete the subset, when to recreate the subset.
It should be pretty simple for you though and if you need to do this with a few things you could have it driven by parameters (e.g. one asks the name of the MDX Subset, another asks the name of what you'd like the hardcoded to be called.... if they are the same an IF function would change the way in which its processed.)
And if its a one off, just "Save As" with the subset.
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key » Sat Mar 17, 2012 3:20 pm
You can do a SubsetCreateByMDX in a TI, then just add and then remove an element to the end of the subset and it will become static.
If you are using contributor have a look at the TIs that come with it and you'll see one of them does precisely this. I can't remember what it is called, but it is something along the lines of }tp_util_convert_dynamic_subset_to_static, or something similarly obvious.
Andy Key
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Post by BariAbdul » Sat Apr 18, 2015 3:22 pm
From 10.2.2 you can directly convert dynamic subset to static subset,Most of you may be already aware of this,Just in case someone misses out:
w-01.ibm.com/support/docview.wss?uid=swg27042401 Thanks
pandinus
OLAP Product: TM1, Cognos Express
Post by pandinus » Sat Apr 18, 2015 7:07 pm
You ever got the SubsetMDXSet to work? On my TM1 10.2.2 FP2 environment this did not work, so I had to revert to the SubsetCreateByMDX, SubsetElementInsert and SubsetElementDelete to make the subset static.
upali
Version: 10.2.2.4
Post by upali » Sun Apr 19, 2015 8:48 pm
I use these two lines...
SubsetCreatebyMDX(cSubset, '{{[' | vDim | '].MEMBERS.ITEM(0)}, {TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [' | vDim | '] )}, 0)}, ASC)}}');
SubsetElementDelete(vDim, cSubset, 1);
vDim is the Dimension and cSubset is the subset you create.
Can be replaced by your MDX statement, while the one before that is used to ensure that the final subset is not empty.
paulsimon
Version: PA 2.0.5
Post by paulsimon » Tue Apr 21, 2015 10:27 pm
The following bit of code does the trick
# Convert the MDX Subset to a Static Subset
# first checking that it does have an MDX Expression
vMDX = SubsetMDXGet( vDim , vSub ) ;
IF( vMDX @<> '' ) ;
  vNumElems = SubsetMDXSet( vDim, vSub , '' ) ;
ENDIF ;
The description on the IBM Web Site is misleading
This function removes the MDX expression from a dynamic subset and converts the dynamic subset to a static subset without locking the underlying dimension.
All of the old elements at the time of the call are saved as elements of the new static subset. The function returns the number of elements that the new subset contains. Optionally, you can also populate the subset with a new MDX expression.
It implies that this will always return a static subset. In practice you actually have to use SubsetMDXSet to set the MDX expression to ''. (You must first have a Subset based on an MDX Expression. If you want to create a Subset with an MDX Expression then just use the usual SubsetCreateByMDX, and then use the above to convert the result of the MDX expression to a Static subset.
BariAbdul
Version: 9.5.2
Post by BariAbdul » Fri Apr 24, 2015 5:35 pm
Thanks a lot,Paul. :)
Emixam
Re: Is there an easy way to convert a dynamic subset to static?
Post by Emixam » Mon Jun 22, 2020 11:58 am
Hello everyone,
I start working for a new client today and there is a strange behaviour with the combination of SubsetCreateByMDX/SubseyMDXSet to make a dynamic subset static.
The following code return a subset with a MDX, everything is good.
However, when I uncomment the last line (to make it static), subset '__Test1' is now empty...
Any idea what happened ? Is there a magic unknown parameter that i'm not aware of ? Am I too tired and I have to go back to bed and review my code after ?
They are using TM1 11.4.0.21/PA 2.0.6
Thanks and have a nice day !
Sorry for my English :)
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Post by gtonkin » Mon Jun 22, 2020 12:45 pm
I have been doing mine like this for a while:
IF(SubsetExists(sDim,sSubset)=0);
SubsetCreate(sDim,sSubset);
ENDIF;
sMDX='TM1SUBSETALL( ['|sDim|'] )}, ['|sDim|']}';
SubsetMDXSet(sDim.Measures,sSubset,sMDX);
SubsetMDXSet(sDim.Measures,sSubset,'');
Create a blank subset if it does not already exist, apply MDX to it then remove the MDX.
scrumthing
Version: 2.0.9
Excel Version: too many
Post by scrumthing » Mon Jun 22, 2020 1:15 pm
Ever since SubsetMDXSet was introduced I only use that one to create dynamic subsets. It seems more robust. For example you do not get an error if your MDX returns an empty set. If you use SubsetCreateByMDX with such a subset an error will occur. But sometimes it is okay to have an empty set if you use it to check for example for users without password or similar things.
And then do it like gtonkin said. Just convert the dynamic one into a static one.
Post by lotsaram » Mon Jun 22, 2020 1:58 pm
You have always been able to use SubsetCreateByMDX to create an empty set without error (you just need to use the undocumented 3rd argument of the dimension name to do it ;) )
Depending on version in PA be careful of using SubsetMDXSet to set blank string as the MDX to convert to static subset. In some versions there is a bug where this will empty the subset (in addition to emptying the MDX). This will be the issue that Emixam has. (PH06270 TI FUNCTION SUBSETMDXSET DOESN'T WORK AS EXPECTED). This issue is marked as fixed in the 2.0.8 release notes.
Adding (then removing) a member is the safe way to do it for all versions. You can use SubsetMDXSet safely for 2.0.8 & 2.0.9
Emixam
Post by Emixam » Mon Jun 22, 2020 2:20 pm
Thanks a lot for the answer guys ! I'll update to the latest version.
Version: PAL 2.0.8
Post by Wim Gielis » Mon Jun 22, 2020 3:06 pm
You can read about it here.
Newest blog article: Selecting elements in the Subset Editor quickly
scrumthing
Version: 2.0.9
Post by scrumthing » Mon Jun 22, 2020 5:25 pm
That is probably why you are an MVP and I am just a regular guy. :-P
Could you please shed some light on that. Now I am really curious.
Emixam
Post by Emixam » Mon Jun 22, 2020 5:54 pm
Based on IBM documentation:
SubsetCreatebyMDX(SubName, MDX_Expression);
However, if you add the 'undocumented 3rd argument' which is the Dimension Name, you won't have any error if your MDX return an empty set.
SubsetCreatebyMDX(SubName, MDX_Expression, DimName);
Wim Gielis made a very good post about MDX statement : https://www.wimgielis.com/tm1_mdxstatements_EN.htm . You'll find more informations on the 3rd parameter in the caveats section.
