TM1 REST API - Getting alias value when retrieving native view
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Post by Harvey » Thu Jan 21, 2021 4:40 am
I'm trying to retrieve and render a view using the REST API. I want to present it similarly to how it looks in Architect. Python is not an option in my dev environment -- so I must do so using native API calls via web request.
I've tried using tm1.Execute, but when the Axes are returned, I don't seem the get the "display name" of the tuples in the rows or columns, rather the raw element name:
api/v1/Cubes('My Cube')/Views('My View')/tm1.Execute?$expand=Axes($expand=Hierarchies($select=Name),Tuples($expand=Members($select=Name))),Cells
returns
    "Axes": [
            "Ordinal": 0,
            "Cardinality": 1,
            "Hierarchies": [
                    "Name": "Column Dimension"
            "Tuples": [
                    "Ordinal": 0,
                    "Members": [
                            "Name": "Measure 001"
            "Ordinal": 1,
            "Cardinality": 33,
            "Hierarchies": [
                    "Name": "Row Dimension"
            "Tuples": [
                    "Ordinal": 0,
                    "Members": [
                            "Name": "Raw Element Name 001"
                    "Ordinal": 1,
                    "Members": [
                            "Name": "Raw Element Name 002"
The Members returned are of type TupleMember, which contains:
                            "Name": "Raw Element Name",
                            "UniqueName": "[Dimension Name].[Hierarchy Name].[Raw Element Name]",
                            "Type": "Regular",
                            "Ordinal": 27,
                            "IsPlaceholder": false,
                            "Weight": 1,
                            "Attributes": {
                                "Caption": "Raw Element Name",
                                "Display Name": "THE ATTRIBUTE I WANT"
                            "DisplayInfo": 131072,
                            "DisplayInfoAbove": 131072
I can see the attribute in the tuple data, but I still don't know which one to display if I have no knowledge of the view structure in advance.
So, I tried getting the selected attribute from the NativeView subset data using the following query:
api/v1/Cubes('My Cube')/Views('My View')?$expand=tm1.NativeView/Rows/Subset($expand=Elements),tm1.NativeView/Columns/Subset($expand=Elements),tm1.NativeView/Titles/Subset($expand=Elements)
which returns:
    "Name": "My View",
    "Attributes": {
        "Caption": "My View"
    "Rows": [
            "Subset": {
                "Name": "",
                "UniqueName": "",
                "Expression": null,
                "Attributes": {
                    "Caption": ""
                "Elements": [
                        "UniqueName": "[Row Dimension].[Row Hierarchy].[Raw Element Name]",
                        "Type": "Numeric",
                        "Level": 0,
                        "Index": 2,
                        "Attributes": {
It seems neither query gives me the selected attribute name -- although I really expected that to be part of the Subset object, if not included as a field in the TupleMember.
If anyone can provide advice on how to get this value, it would be much appreciated.
Harvey.
