Rule for internal cell ref and alternate hierarchies
PavoGa
Version: 10.2.2 FP7, PA2.0.09
Excel Version: 2013 PAW
Post by PavoGa » Thu Oct 15, 2020 8:40 pm
So, I want to reference a cell within a cube located at the intersection of several alternate hierarchies. Do not want to use DB() to an external cube or on this internal reference because speed of [element1, element2, ..., elementN] is faster.
However, the only thing that seems to work is DB(). Have not seen anything in documentation that indicates what I want to do will not work. In fact, the examples for CellValueN provides an explicit example the intended way I plan (and tried!) to use it.
Again, this is attempting to retrieve a value within the same cube, just different hierarchy intersections.
# this saves, but does not return a value.
['MappingTestMeasure'] = N:['Organization:hier_Mapping:MappingElement',
    'HR Level:hier_Mapping:MappingElement',
    'Test_Cube Measure:hier_Mapping:53PostYearFactor'];
['MappingTestMeasure'] = N:['Organization':'hier_Mapping':'MappingElement',
    'HR Level':'hier_Mapping':'MappingElement',
    'Test_Cube Measure':'hier_Mapping':'53PostYearFactor'];
# this errors when saving.
['MappingTestMeasure'] = N:['Organization:hier_Mapping':'MappingElement',
    'HR Level:hier_Mapping':'MappingElement',
    'Test_Cube Measure:hier_Mapping':'53PostYearFactor'];
## this returns the desired value.
['MappingTestMeasure'] = N:DB('Test_Cube',
    !Version,
    !Fiscal Period,
    'Test_Cube Measure:hier_Mapping':'53PostYearFactor');
## Errors when saving.
    !Version,
    !Fiscal Period,
    'Test_Cube Measure':'hier_Mapping':'53PostYearFactor');
# This saves, but returns nothing.
['MappingTestMeasure'] = N:CellValueN('Test_Cube',
### created distinct hierarchies and elements for each dimension.
### this returns the desired value.
    !Version,
    'Organization:hier_Mapping_Org':'MappingElement_Org',
    'HR Level:hier_Mapping_HR':'MappingElement_HR',
    !Fiscal Period,
    'Test_Cube Measure:hier_Mapping_Measure':'53Factor');
    'Organization':'hier_Mapping_Org':'MappingElement_Org',
    'HR Level':'hier_Mapping_HR':'MappingElement_HR',
    'Test_Cube Measure':'hier_Mapping_Measure':'53Factor');
So, am I doing something wrong and, if so, what is it?
Ty
Cleveland, TN
