NewDateFormatter Use
MarenC
Excel Version: Excel 2016
Post by MarenC » Thu Jul 30, 2020 10:31 am
I want to get the serial date of the following date:
31/07/2020.
Normally I would subst this and use DayNo.
But I thought I would try the following:
cDate = '31/07/2020';
vDateFormater = NewDateFormatter('');
vDateCompareSerial = ParseDate(vDate, 'dd/mm/yyyy');
vDateCompare = FormatDate( vDateCompareSerial, 'yyyy-mm-dd' );
I get the following results when I output to excel:
vDateCompareSerial = 21945.004861111
vDateCompare = 31/07/2020
But vDateCompareSerial equates to 31/01/2020 and not 31/07/2020.
What is going on?
Maren
Version: PAL 2.0.8
Re: NewDateFormatter Use
Post by Wim Gielis » Thu Jul 30, 2020 11:43 am
Did you check the documentation on the date patterns ?
http://userguide.icu-project.org/formatparse/datetime
I would use 'dd/LL/y' and 'dd LL y' for your patterns.
https://www.wimgielis.com ==> 117 TM1 articles and a lot of custom code
Newest blog article: Friday the 13th
MarenC
Post by MarenC » Thu Jul 30, 2020 12:18 pm
Hi Wim,
I didn't know I did need to check those patterns so thanks for that.
I see the issue now, the small m was presuming minute.
If I change it as follows it appears to work:
vDateCompareSerial = ParseDate(vDate, 'dd/MM/yyyy');
vDateCompare = FormatDate( vDateCompareSerial, 'dd/MM/yyyy' );
Your patterns work too but I wanted the patterns to resemble the vDate and M is more familiar than L for months
thanks for your assistance
Maren
Version: PAL 2.0.8
Post by Wim Gielis » Thu Jul 30, 2020 12:35 pm
Hi Wim,
Maren
indeed MM is an option too.
