How set alternative hierarchy in Architect or Performance Modeler.
Palczan
OLAP Product: TM1 Cognos
Version: 11.3.0.27
Excel Version: Office 365 MSO 64bit
Post by Palczan » Fri May 29, 2020 8:43 am
Hello Guys,
i have a problem with alternative hierarchy. Unfortunately i can't find a location where i can set a new hierarchy.
Now I'm using a performance modeler, architect and tm1 web. i don't have a access to PAW :cry:
Do you know where can I set a second hierarchy in view or subset?
Thanks all
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: How set alternative hierarchy in Architect or Performance Modeler.
Post by Elessar » Fri May 29, 2020 9:20 am
PAW is the only interface where you can manage hierarchies.
In Architect, PM you should use TI for this
Palczan
Version: 11.3.0.27
Post by Palczan » Fri May 29, 2020 9:48 am
i create a alternative hierarchy based on TI, but i have a problem with display this hierarchy.
I can't find a location, where i can set hierarchy in view or subset.
Do you know which function set hierarchy in subset or view ?
Best regards
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Fri May 29, 2020 10:02 am
There. Is. No. Such. Thing. In. Perspectives. Or. Architect. Or. PM.
You need to use PAW.
https://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
Version: 10.2.2., PAW
Post by Steve Rowe » Fri May 29, 2020 1:00 pm
Just in case you have access to Planning Analytics for Excel you can use Hierarchies there as well.
If you have not installed PAW (as opposed to not being able to access it), then you won't be able to use (all of) PAfE and so won't be able to report with hierarchies.
