Process Tree Expanding Error in PAW
macsir
Version: PAL 2.0.8
Post by macsir » Mon Mar 09, 2020 12:49 am
Hi, all
We are on PAW 2.0.46 and I found this error when expanding process tree. Other trees are fine. Any idea?
Caused by: com.fasterxml.jackson.core.JsonParseException: Invalid UTF-8 start byte 0xa0
at [Source: (com.ibm.ba.pm.harmony.common.tm1.TM1RestResult$InputStreamProxy); line: 1, column: 268191]
Seems like some UTF-8 characters is causing the issue but I couldn't find any.
Thanks.
kangkc
Version: 9.x
Excel Version: 200x
Re: Process Tree Expanding Error in PAW
Post by kangkc » Tue Mar 10, 2020 12:17 am
Hi, all
Thanks.
Just a wild guess, some process name uses special characters that're reserved by JSON and it is not handled in PAW ?
macsir
Version: PAL 2.0.8
Post by macsir » Tue Mar 10, 2020 3:03 am
No, I went through all of them. Can't find any. Thanks.
macsir
Version: PAL 2.0.8
Post by macsir » Fri Mar 13, 2020 12:38 am
I even tested with following statement which works fine.
https://PROD SERVER:8010/api/v1/Processes
macsir
Version: PAL 2.0.8
Post by macsir » Wed Mar 18, 2020 1:50 am
I recopy the whole data folder again from 10.2.2 to PA. The issue went away and not sure why. Pretty much they are same bunch of processes.
