Active Form swoping row dimensions around
JonoRowe
Version: 2.09
Excel Version: 16
Post by JonoRowe » Fri Jan 24, 2020 11:40 am
I am trying to make an active form based on a view i have. two dimensions on the row side. the one dimension is all n-level and the other dimension is a consolidator with 2 elements beneath.
Example:
Test 1 All Data Sources
Calculated
Adjustment
Test 2 All Data sources
Calculated
Adjustment
When i active form this view out into excel the active form swops the dimensions starting from the second row.
Example:
Calculated Test 1
Adjustment
Calculated Test 2
Adjustment
I am not sure as to why this is happening ? Both dimensions do have saved subsets.
TIA
