Tm1 Datasource for Power BI
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 » Fri Jan 10, 2020 8:13 am
Hello Everyone,
I am currently looking forward for an option to connect TM1 to Power BI tool without using any third party connector.
I read in some forum that, creating ODBC datasource using Cognos Connection Framework Manager and using ODBC connecting to Power BI. I am not sure, I have to try this option.
I would like to know anybody has come across this situation? or any other feasible solution using REST api or MDX statement?
Thanks in advance.
Re: Tm1 Datasource for Power BI
Post by David Usherwood » Fri Jan 10, 2020 9:48 am
I didn't pursue this but it looks like you could use PowerBI's Python integration to link to TM1PY:
https://www.tm1forum.com/viewtopic.php? ... rbi#p71322
Post by lotsaram » Fri Jan 10, 2020 10:57 am
That's a starting point, but really only a starting point.
Well you NEED a connector as PowerBI doesn't connect natively to TM1. Either you write your own or you look at one of the commerical alternatives already available.
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Fri Jan 10, 2020 11:11 am
Thanks for the post.. I have gone through link.
As I am very new to all these PowerBI, TM1PY etc, can you provide me some link or steps on how to proceed further. It would be a great help for me:)
I would like to create an own connecto to connect Power BI with TM1. I dont know python, how long will it take to create a connector Interface?
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Fri Jan 10, 2020 2:53 pm
In Python, I can use TM1PY library, and I can access the TM1 Data. In Power BI I can use Python, so that via Python Scripts I can access TM1.
Is my understanding correct? if not kindly correct me.
MariusWirtz
Version: 10.2.2.6
Post by MariusWirtz » Mon Jan 13, 2020 7:54 am
Hello Kavitha2002,
Regarding,
"In Python, I can use TM1PY library, and I can access the TM1 Data. In Power BI I can use Python, so that via Python Scripts I can access TM1."
Yes your understanding is correct.
In fact I already started working on TM1py features that simplify the retrieval of TM1 data for PowerBI.
I described my ideas briefly here.
https://github.com/cubewise-code/tm1py/issues/180
I think it would only take a few days of work to implement this features.
The WIP Merge Request you can find here:
https://github.com/cubewise-code/tm1py/pull/182
However, currently this feature does not have highest priority on my list. I expect to continue working on it towards end of Q1 or Q2.
If you are interested in participating and contributing code that would be great!
kavitha2002
OLAP Product: tm1
Excel Version: 14
Post by kavitha2002 » Mon Jan 13, 2020 8:45 am
@MariusWirtz Thanks for your confirmation and reply.
Based on your reply, my understanding is there is a possibility of implementing via TM1PY.
Via Python scripts in PBI, data will be live or do we need to refresh the data by writing some scheduling.
As I said am completely new on this area, so will try my level best.
