More info on TM1Project.json file
luizg2019
OLAP Product: TM1 - PAW & Architect
Version: PA 2.0.7 - PAW 2.0.44
Excel Version: office 2016
Post by luizg2019 » Thu Dec 05, 2019 6:09 pm
Hi!
I'm trying to use GIT on our servers but IBM's documentation is not very detailed on this subject, they say you "SHOULD" create a tm1project.json file for each model but don't say where to save it, I tried creating it on my data folder but it made no difference when I sent a GitPush command.
Does anyone know where should I create this file and how should I proceed to use this?
Thank you.
Mike Cowie
OLAP Product: TM1, MSAS
Version: Anything thru 11.x
Excel Version: 2003 - 2016
Re: More info on TM1Project.json file
Post by Mike Cowie » Thu Dec 05, 2019 11:00 pm
Hello:
The only way to work with the project file that I'm aware of is via the REST API-- I don't believe it can be managed directly with a file in the data directory structure.
To create/update that project file create json which defines your tm1project spec, for instance:
  "Version": "1.0",
  "Name": "My Model",
  "Settings": {
    "Performance": {
      "MTQ": {
        "MTFeedersAtStartup": false
  "Tasks": {
		"Refresh Security":
      "Process": "Processes('Refresh Security')",
      "Parameters": []
  "Objects": {},
  "Files": [
		"\\admin\\*\\*"
  "Ignore": [
		"Processes('Ignore Me')"
  "Deployment": {},
  "PrePull": [],
  "PostPull": [],
  "PrePush": [],
  "PostPush": []
And POST or PUT that json to this special TM1 REST API url used to access the tm1project definition:
.../api/v1/!tm1project
You can review what's currently in there with a GET-- by default I believe it's blank until you POST/PUT something there.
Hope that helps! (and, yes, it's not that clearly documented right now)
Edward Stuart
Version: All
Excel Version: All
Post by Edward Stuart » Fri Dec 06, 2019 8:54 am
Excellent work Mike, I'm looking forward to testing this further.
For those also looking into this Yury has posted (yet) another great blog on Git Integration
https://ykud.com/blog/cognos/tm1-cognos ... tm1-part-1
luizg2019
Post by luizg2019 » Fri Dec 06, 2019 12:25 pm
Wow. I would've never guessed based on the documentation :lol: :lol: :lol:
Thank you very much for your help Mike!
Thank you for sharing this link Edward, it's definitely more informative than the official documentation. :D
luizg2019
Post by luizg2019 » Mon Dec 09, 2019 2:07 pm
  "Version": "1.0",
  "Name": "My Model",
  "Settings": {
    "Performance": {
      "MTQ": {
  "Tasks": {
		"Refresh Security":
      "Parameters": []
  "Objects": {},
  "Files": [
		"\\admin\\*\\*"
  "Ignore": [
  "Deployment": {},
  "PrePull": [],
  "PostPull": [],
  "PrePush": [],
  "PostPush": []
Hi mike! Do you know how can I specify for control cubes to be included in the git context?
I tried using the "(not) ignore" section in tm1project but the control cubes were not added to git, and it made the gitpush took a lot more of time to complete.
  "Version": "1.0",
  "Name": "Test",
  "Ignore": [
		"!Processes('}*')",
		"!Dimensions('}*')",
		"!Cubes('}*')"
Thank you.
EDIT:
Nevermind.
Found the answer. Turns out the wildcard is NOT supported for control objects :oops:
So you have to manually list one by one if you want them included in the git as well, which is very annoying because when you're moving new dimensions between servers, its attributes will not be transferred unless you specify each "}ElementAttributes_Dimension" cubes to be transferred as well.
ykud
Post by ykud » Mon Jan 06, 2020 5:01 am
Hi there,
How did you manage to include the control cubes in the end?
Via !Ignore, like this?
  "Ignore": ["!Cubes('}ElementAttributes_DimensionA')"]
Or you're 'including' them explicitly in {objects}? Can you please share your tm1project.json?
I'm trying to add them in something like all_cubes.json file to be able to use Link: all_cubes.json, but failing so far. Quite annoying :(
Also, maybe you or Mike have played with it and know the answer:
Say I want to promote only 3 changed objects from one server (A) to another (B), but I have 10 more objects changed on A that I don't want to promote yet. I thought this would be something like listing the 3 objects in the "deployment" as objects so that it overrides the primary definition, but so far I am struggling to get any Pull request to ignore the other 10 objects. Any pointers?
Yuri
luizg2019
Post by luizg2019 » Tue Jan 07, 2020 1:04 pm
Hi there,
Hello!
Yes, using the (not) !ignore feature. But you have to save the tm1project settings before doing a git pull.
I didn't get to play a lot with the tm1project setting because I didn't have time and the bad documentation also discourages me.
But my tm1project.json was something like:
  "Version": "1.0",
  "Name": "Test",
  "Ignore": [
		"!Dimensions('}Clients')",
		"!Dimensions('}ClientProperties')",
		"!Cubes('}ClientProperties')"
I also ran into that issue. What I did was manually ignoring the objects on the tm1project.json from server A before doing a commit/gitpush so when you do a gitpull on server B it won't overwrite the objects that you ignored.
ykud
Post by ykud » Tue Jan 07, 2020 9:33 pm
Hello!
Thanks heaps! That document is indeed very confusing and vague, I'm quite annoyed about having to 'guess & try' so much around it.
Yep, I know that if you don't have any other objects in the repo (don't push or delete from git), they will no be pulled. Just hoping this is not the only way as that's kinda the end of trying to have a single git repo for your tm1 server. I'll try and see if I can get some pointers from IBM re this, things can't be that bad.
Thanks again,
Yuri
