Tm1 Alias
vikram.balaji16
OLAP Product: IBM Cognos
Excel Version: 1808
Tm1 Alias
Post by vikram.balaji16 » Wed Oct 30, 2019 1:50 pm
How to get an alias name by derving the element name in TM1 turbo integrator process. can some one please help on this
ascheevel
Version: PA 2.0.8
Re: Tm1 Alias
Post by ascheevel » Wed Oct 30, 2019 2:02 pm
Aliases are string attributes, you can use ATTRS to return the attribute value of an element.
https://www.ibm.com/support/knowledgece ... attrs.html
vikram.balaji16
Excel Version: 1808
Re: Tm1 Alias
Post by vikram.balaji16 » Wed Oct 30, 2019 2:25 pm
Thank you soo much
howard40116
OLAP Product: PAL
Version: PAL 2.0.4
Excel Version: excel 2010
Re: Tm1 Alias
Post by howard40116 » Fri Nov 01, 2019 1:25 am
##Reminder
When the alias is the same as the principle element name
You can go to the attribute viewer and the alias column will display the same name as the principle element.
But when you open attribute Cube today, you will find that the cell is blank.
So when you use "ATTRS" and "CELLGET", only the blank is taken.
Remember to add more judgments and take the element name from principle element name.
Example:
sAlias=ATTRS(sDim,vEle,'Alias');
IF(sAlias@='');
     sAlias=vEle;
ENDIF;
https://github.com/howard40116/Rebellio ... 20note.txt
Version: PAL 2.0.8
Re: Tm1 Alias
Post by Wim Gielis » Fri Nov 01, 2019 8:59 am
Or create a generic process that runs once in a while to loop over all dimensions. See whether there are are alias. Populate the empty cells in the }ElementAttributes cube with the element name.
Additional functionality:
- give a cube name and the process only goes through the dimensions of that cube
- treat all hierarchies of the dimensions
- use wildcards in the dimension to treat all dimensions starting with Rpt_* for example
A new Bedrock process might be born 😉
http://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
Re: Tm1 Alias
Post by lotsaram » Fri Nov 01, 2019 1:48 pm
Actually I think there might be one already! We already have one in the "consultant toolkit" that basically does exactly this; find blank cells for alias attributes (and Caption regardless whether defined as String or Alias) and populate with principal name.
Ensures that CellGetS and DB return the same value as AttrS.
Of course it's not a bedrock process but it might as well be. There's hardly anything too special about what it is doing.
Version: PAL 2.0.8
Re: Tm1 Alias
Post by Wim Gielis » Fri Nov 01, 2019 5:21 pm
I am not aware of the "consultant toolkit" is, I have mine though, in which I have such a process.
howard40116
OLAP Product: PAL
Version: PAL 2.0.4
Re: Tm1 Alias
Post by howard40116 » Mon Nov 04, 2019 6:38 am
Maybe Bedrock4 can add this ti for public ,and then we just need setting chore by daily in this bedrock :D :D :D
