TM1 REST API Postman Requests
SarahChang
OLAP Product: none
Version: none
Excel Version: none
Post by SarahChang » Fri Jun 28, 2019 5:36 pm
After referencing the swagger file from IBM's website (https://ibm.ent.box.com/s/7qtprz4zntkhl ... pol9w1z5vr), I've been trying to find working Postman requests to IBM TM1 for:
1) POST /Cubes('{Name}')/ibm.tm1.api.v1.UpdateCells
I have tried the request body:
  "Updates": [
      "Tuple": [
     	"Name": "Sales" ,
     	"UniqueName": "[}Cubes].[}Cubes].[Sales]",
     	"Type": "N_Elem",
     	"Level": 0,
     	"Attributes": {},
     	"Hierarchy": {},
     	"Parents": [],
     	"Components": [],
     	"Edges": [],
     	"LocalizedAttributes": []
      "Value": "READ",
      "ReferenceCube": {},
      "ReferenceCell": []
  "Order": "NoOrder"
but I get back code 278, "Could not find entity reference in payload."
2) GET for TM1SecurityRightRead(), TM1SecurityRightWrite(), TM1SecurityRightNone(), TM1SecurityRightReserve(), TM1SecurityRightLock(), and TM1SecurityRightAdmin().
If anyone could point me in the correct direction, it would be greatly appreciated.
Thank you!
PlanningDev
Version: 2.0.5
Re: TM1 REST API Postman Requests
Post by PlanningDev » Mon Jul 01, 2019 9:46 pm
Are you trying to get data from a cube or trying to write data to a cube? Or just looking for working examples of a few types of operations?
SarahChang
OLAP Product: none
Version: none
Excel Version: none
Post by SarahChang » Tue Jul 02, 2019 5:04 pm
Thank you for the response - I'm mainly just looking for examples that will work in Postman.
PlanningDev
Version: 2.0.5
Post by PlanningDev » Tue Jul 02, 2019 5:47 pm
Get dimensions that have a name matching the specified text
http://server:port/api/v1/Dimensions?$filter=contains(Name, 'search text here')
Remove element from parent
http://server:port/api/v1/Dimensions('DimName')/Hierarchies('HierarchyName')/Edges(ParentName='ParentElementName', ComponentName='ChildElementName')
Get all element names from Dimension/Hierarchy
http://server:port/api/v1/Dimensions('dimname')/Hierarchies('hierarchyname')/Elements?$select=Name
ExecuteCubeView and Get cellset back
http://server:port/api/v1/Cubes('CubeName')/Views('ViewName')/tm1.Execute?$expand=Cells
Not sure if you have seen this guide but it has plenty of examples on how to perform various operations
https://www.ibm.com/support/knowledgece ... st_api.pdf
ByronB
OLAP Product: TM1 + BI
Version: TM1 10.2
Excel Version: Excel 2010
Post by ByronB » Fri Jul 05, 2019 3:06 am
There is a Postman collection for the TM1 REST API available for free, I would recommend starting with this collection, just Google TM1 and Postman and you will find it. There are also articles which will explain to you how to connect to your TM1 instance.
I hope this help
