Getting all the children of an element
Rtel
Post by Rtel » Tue May 28, 2019 10:27 pm
Hi, In a TI, I want to loop through all the child elements of an element passed as an argument.
For eg if Element name argument to TI is 'Element 1' , TI should iterate through
Element 1.1
Element 1.2
Element 1.3
Element 1.3.1
Element 1.3.2
I tried ElementCount function, but it is throwing error as 'variable ElementCount is UNDEFINED' !!!
I tried getting count using ELCOMPN but it returns 3 for 'Element 1' (instead of 5 that I need) and I want to loop through all the children under Element 1.
If I pass 'Element B' as an argument then it should return only 'Element B' since it does not have any child element.
Logic that I thought of ..
IF Element consolidated
Get the Count of all the children (say iAllChild)
While iCounter < iAllChild
loop thorugh all the Children using the Index
End
else
return same element
endif
Please advise how to accomplish above or if there is a better way.
Rtel
Sample Dimension
Element A
Element 1
Element 1.1
Element 1.2
Element 1.3
Element 1.3.1
Element 1.3.2
Element 2
Element B
Element C
Rtel
Re: Getting all the children of an element
Post by Rtel » Tue May 28, 2019 10:51 pm
To add to my previous question
how to use this MDX from TI to iterate through all the elements in the subset
{TM1DRILLDOWNMEMBER( {[Dimension].[Element]}, ALL, RECURSIVE )}
Version: PAL 2.0.7
Post by Wim Gielis » Tue May 28, 2019 11:17 pm
If you have an MDX expression, you can use SubsetCreateByMDX to create a subset with said MDX, and then loop through the subset:
sDim = '...';
sSub = '...';
nMax = SubsetGetSize( sDim, sSub );
nCtr = 1;
While( nCtr <= nMax );
  sEl = SubsetGetElementName( sDim, sSub, nCtr );
  nCtr = nCtr + 1;
End;
If you don't have an MDX expression, you can loop over all dimension elements and see if they belong to the chosen element:
sDim = '...';
nMax = Dimsiz( sDim );
nCtr = 1;
  sEl = Dimnm( sDim, nCtr );
  If( Elisanc( sDim, 'the consolidated element', sEl ) = 1 );
  EndIf;
  nCtr = nCtr + 1;
End;
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 service with AutoHotKey
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Wed May 29, 2019 10:30 am
Best solution to create dynamic subset:
MDX='your mdx';
vLastDim='DimensionName';
vSubset='randomName';
SubsetCreate(vLastDim, vSubset, 1 );
SubsetMDXSet(vLastDim, vSubset, MDX );
SubsetMDXSet(vLastDim, vSubset, '');
how to iterate subset answered Wim
samba.kesinakurthi
Version: 10.2.2, PA2.0
Post by samba.kesinakurthi » Wed May 29, 2019 2:47 pm
You can also try the below as MDX to create the subset for your requirement
SubsetCreateByMDX(SubsetName, '{Descendants([Dimension].[Element 1])}');
Then you can loop through the subset to access the elements
Rtel
Post by Rtel » Wed May 29, 2019 3:56 pm
Hello All, thanks for all your help. Following is the working code that I would like to share. From the responses I understand that there are
1) two diff MDX to create subset
2) two way to create Dynamic subset
( I will try both to understand the difference)
Rtel
sDim = 'TestMember' ;
sElement = '0246 LLC ' ;
sSubSet = ' sub_Member ' ;
SubsetCreateByMDX ( sSubSet , ' {TM1DRILLDOWNMEMBER( {[ ' | sDim | ' ].[ ' | sElement | ' ]}, ALL , RECURSIVE )} ' ) ;
nSubSetSize = SubsetGetSize( sDim, sSubSet ) ;
nSubSetCounter = 1 ;
While ( nSubSetCounter <= nSubSetSize ) ;
sEl_Member = SubsetGetElementName ( sDim, sSubSet , nSubSetCounter ) ;
Asciioutput ('test.cma', 'Element Name', sEl_Member );
# Here I intend to change one of the measure for each of these members using CellPutS
nSubSetCounter = nSubSetCounter + 1;
End;
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Post by gtonkin » Wed May 29, 2019 4:54 pm
Glad you found a solution-was going to go ELCOMP direction but saw after posting that you had multiple levels.
